It is currently Fri Jul 18, 2025 12:34 pm
 Post subject: speedo question
PostPosted: Wed May 13, 2009 3:50 pm
Just finished the last box of bits and found this speedo in it. It has two odometers in the face and two seperate drives on the back.I have included a pic of the std[I think] type for early 850 showing the difference.
Open to any suggestions or ideas
www.minisprintgt.com
PostPosted: Wed May 13, 2009 4:02 pm
Trip meter? any way of resetting it to zero?
David L
In the UK they did make tripmeter speedos. Is that another drive on the back (pic is out of focus) or is it a reset knob/drive square?
It would have had a 180° bit of speedo cable to a knob next to the speedo. My Fiat had this setup too.
PostPosted: Wed May 13, 2009 4:33 pm
It has a separate drive [top LH corner on back] but is a smaller thread. it resets by pushing the drive in. That is only thing I can see on it to re-set. Seems a bit stupid way of doing it.It's a bit gummed up but the numbers try to move, or maybe they wanted you to see the milage in stero :)
I am wondering what model car it came from.
PostPosted: Wed May 13, 2009 4:36 pm
Any model numbers on it David or revolutions per whatever markings (can't remember the wording now but the code that tells you what it works with ) ?
PostPosted: Wed May 13, 2009 4:41 pm
yeah it`s a seperate trip metre & should have a short cable attached to it with a small Knurled knob on the end of it.
i have a couple of these speedos
They`re cool hey?
PostPosted: Wed May 13, 2009 4:56 pm
The top one is miles and tenths. It only goes to 999.9
the bottom one is also miles and tenths going by the colours of the numbers. They are a bit faded. Max speed 90mph[very optimistic]
The only serial No. I can't completely read, but it's 51 118 605 01***
It was in this center housing. a paper or carboard one not plastic.
Thanks Doc about the tip off with the drive, Now I know what that liitle bit was that I threw into the trailer with the other rubbish :x :x . Oh well back thru the rubbish and find it.
PostPosted: Wed May 13, 2009 5:03 pm
Hey Matt ,got any idea what these were fitted into. and can you PLEEEEEEEEEEEEASE post a pic of the bit you are talking about. I want to make sure it is the right bit before I go thru all the junk it the trailer :evil: :evil:
I have had enough of yes i will no i wont keep it
PostPosted: Wed May 13, 2009 5:46 pm
It looks like an 850 speedo but isn't! I bet someone has had a play with it.
Lots of MGs, Morris and big Austins had the trip meter, they had a cable that run from the back of the speedo to the bottom of the dash.
This one on Ebay is from a Morris Cowley, it shows the re-set cable..
PostPosted: Wed May 13, 2009 8:49 pm
Ha!!!! Saved me taking a pic & hosting & posting
it looks just like that one that morris 1100 posted
too easy :-)
PostPosted: Wed May 13, 2009 10:17 pm
The Mini King
This is from the very early Mini 1960 1961 would be a sought after item
PostPosted: Wed May 13, 2009 10:43 pm
I was a happy s a pig in sh*t when I found the housing. The rats had eaten half of the one that was in my car. All I need now is some seats, the bloody things ate them as well. at least the cat ate the rats :D
Users browsing this forum: Bing [Bot] and 84 guests
