It is currently Fri Jul 18, 2025 3:08 pm
Post new topic Reply to topic  [ 123 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9
PostPosted: Wed May 13, 2009 5:09 pm
what should they be set at..?
25 thou
PostPosted: Wed May 13, 2009 5:51 pm
Thanks Mick. :)
I wiped out the inside of the dissy cap, it all looked pretty clean in there... Still felt rough when I raised the revs, though. Rough enough to put a little bounce into the car (at harmonic revs - and unloaded). :? Will try the plugs tomorrow. It's dark here now, and I don't like running the car at night. Don't want to annoy the neighbours. :roll:
PostPosted: Thu May 14, 2009 2:00 pm
I gapped the points inside last night, installed them this morning, and fired it up. All sounding smoother! :D So I tried taking it out. And it was back to terrorizing the neighbourhood. :twisted: :lol: The tune felt no worse than it was on points (i.e. timing/needles, etc), the engine revved smoothly, it idled higher than it ever has before (choke off)... :) Didn't bother to remove plug leads from the new plugs, I didn't feel like copping another few boots. :lol: :roll: So, I'm thinking that, in the process of changing to electronic ignition and doing and oil change, it's probably not a bad recommendation for people to change their plugs at the same time. :wink: I don't know when mine were last done. :oops: Certainly not while I've had it (although I maintain I wouldn't have done 1000 miles since I've had it on the road).
None of that explains why the plugs were fouled, but I'll just check this set in 100 miles or so, and see what they look like. :)
