It is currently Tue Aug 19, 2025 5:47 pm
 Post subject: brakes
PostPosted: Fri May 15, 2009 5:59 pm
hey guys i have blead all my brakes and there is no more air in the line at all i have put about a bottle of fluid thru each wheel and still no pedel i have adjusted them all the way up and still no pedel untill u pump it even if i adjust them untill the pads are locked on i still dont get pedel untill i pump them i have just redone the front brakes and put twin leading shoes on it cause i had 850 ones on it to start with what am i doing wrong what can i do to fix it and i am sure it aint my master cylinder cause when i pump them i get pedel but if i hold the pressure it dont leak any idea ????? please it is in my drive way just had rego put on it.........:(
PostPosted: Fri May 15, 2009 6:26 pm
ok,,, go & """UN_Adjust""" your front brakes completely,,, mke sure the cyl pistons are right back home
,,, then bleed them,,,
then Adjust them up again
after you have done all that , report back here with the results
OK???
PostPosted: Fri May 15, 2009 6:44 pm
umm what will this achieve ?????????? just out of curiosity
PostPosted: Fri May 15, 2009 6:45 pm
I've had that trouble. Putting new pads on solved it for me. Looking at the pads was deceptive, I thought the old ones had plenty of meat left, however once they get so far down the pedal just wasnt acheivable.
Good Luck with it.
PostPosted: Fri May 15, 2009 6:57 pm
the front cyls on the "twin-Leading" show set up, are mounted vertically,,, so at least one of them (on both sides of the car) will have an "Avaliable" air pocket under te adjusted up cyl piston
when you "Un-Adjust" the fronts, you are effectively pushing that piston back down so the bottom of it becomes Level with the bleed hole & the air can then escape,,,
if you were to have the shoes adjusted up while bleeding, then the air will be held captive in the cyl, above the bleed hole & under the piston
sooo,,,, """UN-Adjust the front brakes,,, Making sure the pistons are right home,,, then bleed them,,,, & then adjust them back up.
the 2nd pump of the pedal should find it high & hard
If not ,,, then you have other problems.
you don`t have to trust me,,, cause i`m not there helping to diagnose the problem,,, but i have done this mini repairs thing for a little while :-) :-) :-)
PostPosted: Fri May 15, 2009 7:20 pm
Trust him, he does know a little bit about Mini's.
Only a bit mind you. :wink:
67 Deluxe - Red and white
69 Deluxe - Sugercane Grey
PostPosted: Fri May 15, 2009 7:36 pm
Tomboss Breweros
Never done that but it sounds like a very effective method.
My method of opening a nipple then getting an assistant to pump the pedal 15 times FAST then close the nipple with the pedal down works every time for me.
Remember to re-fill the master.
I managed to fill and bleed the dry assembled system on my mini using 1 bottle, mind you that bottle cost me $38 :shock:
kimini wrote:
Jimmyinamini wrote:
Users browsing this forum: Bing [Bot] and 50 guests
