It is currently Tue Aug 19, 2025 11:13 am
 Post subject: ball joint grease
PostPosted: Fri May 15, 2009 5:46 pm
just starting to fit the new ball joints
what type and grade grease do you guys recommend for new ball joints?
thanks
leighton
PostPosted: Fri May 15, 2009 5:49 pm
I use moly
PostPosted: Fri May 15, 2009 6:05 pm
TheMiniMan wrote:
I use moly
Does your wife know :shock:
PostPosted: Fri May 15, 2009 6:24 pm
Shhh,,, don`t tell anyone but Molly is a really nice girl & i don`t want her to get it trouble :-)
PostPosted: Fri May 15, 2009 6:43 pm
Any girl that greases your ball-joints is a keeper. :mrgreen:
PostPosted: Fri May 15, 2009 6:58 pm
she stepped in some mud the other day, so i video-ed it & got some "Dirty-Footage" :-)
PostPosted: Fri May 15, 2009 7:23 pm
I use whatever EP2 lithium grease is cheapest in cartridge form.
I've found buying them from a BP servo is cheaper now than Supercrap.
PostPosted: Fri May 15, 2009 7:28 pm
what do you use in wheel bearings.
I used moly in the ball joints, but i used caltex HTB in the bearings.
PostPosted: Fri May 15, 2009 7:51 pm
Castrol HTB in the bearings, LMM in CVs.
Steering racks I use Castrol LSX90. It's an LSD diff oil, has additives for metal to metal sliding contact- good for where the rack slides on the steel pressure pad.
PostPosted: Fri May 15, 2009 8:07 pm
That's good, I still have a bottle of LSX90 left over from the HQ race car (but don't HQs run open diffs? 8) :lol: )
PostPosted: Fri May 15, 2009 8:41 pm
I thought they used no oil at all in the diff so it welds itself up after a couple of corners...
