It is currently Sun Aug 03, 2025 10:11 am
 Post subject: How much oil
PostPosted: Sun May 17, 2009 8:47 pm
Location: Burpengary,Brisbane Nth(the better side of Bribane)
How much oil does it take to fill a motor to it's correct level when you do a change including filter. I seem to be using nearly 5.8 litres or there abouts to get it to the top level on the dipstick. :?
https://t.me/pump_upp
PostPosted: Sun May 17, 2009 8:56 pm
Seems a bit to much to me. I have about half a pint left out of 5 litres when I did mine yesterday. Depends a bit on how much you pour into the filter.
Cheers, Ian
PostPosted: Sun May 17, 2009 8:58 pm
This space for rent
I normally fill the filter to the point where I can screw it on without spilling, and use pretty close to 5L exactly, leaving 1L of KMX for top-ups ;)
PostPosted: Sun May 17, 2009 8:59 pm
Always less than 5 litres, even with the big cartridge filter.
PostPosted: Sun May 17, 2009 9:00 pm
Going by the book it's to much but do I go by the book or the dipstick ?
PostPosted: Sun May 17, 2009 9:01 pm
By memory the haynes book says 4.8 litre plus filter!
But correct me if i am wrong
Louis
PostPosted: Sun May 17, 2009 9:03 pm
This space for rent
Louis
Close, 4.83 litres including filter ;)
PostPosted: Sun May 17, 2009 9:04 pm
Louis
Depends on the filter. :wink: The spin-on is smaller than the cartridge. There is a bit of variation in the spin-ons as well.
Tomboss Breweros
Stupid question, but is your car sitting flat?
I put in a straight 5L, it allows for the first month of leaks :oops:
kimini wrote:
Jimmyinamini wrote:
PostPosted: Sun May 17, 2009 9:06 pm
I would be looking carefully at your dipstick. There is something wrong. Maybe the stick or the tube is the wrong one.
PostPosted: Sun May 17, 2009 9:07 pm
Might be a stupid comment but i have done that.
Allow a bit of time for the oil to go down the sump :?, don't check strait away.
Louis
PostPosted: Sun May 17, 2009 9:08 pm
Might measure it next time and go by the book. And yes it's on flat ground.
PostPosted: Sun May 17, 2009 9:11 pm
Just checking , this is a manual box isn't it ?
PostPosted: Sun May 17, 2009 9:15 pm
Yes manual MK1 cooper motor.
PostPosted: Sun May 17, 2009 9:33 pm
Are you sure that you've got a 6 litre container of oil? Maybe you've only got a 5 litre this time. Just an idea.
