It is currently Thu Aug 07, 2025 11:12 am
PostPosted: Sun May 17, 2009 11:33 am
You mentioned underbody colour. I like the idea of colour underneath. Be mindful that some deadeners are black and cannot be overpainted. I like the contrast of having body colour against black bits and silver pipes.
Here are some examples:
Then again at the end of the day - who is going to look under your car anyway!
Dave K.
PostPosted: Sun May 17, 2009 12:07 pm
I'm certainly a bit wiser with all the input. Dave that is sensational, and has won me, great photos. Is that 2K ?
Thanks
Brian
PostPosted: Sun May 17, 2009 1:08 pm
WOW!
I had no idea what a difference underbody colour was like!
Must remember when I paint the grunt in 14 years! :D :D
mooo, I'm a pig!
PostPosted: Sun May 17, 2009 9:03 pm
Thanks
Brian
This project was done in Acrylic. If I had access to a proper booth I would have no problem with going 2 pac. I painted this one in the drive way so chose to go acrylic. Just a comment about being legal to paint 2 pac or not - even if I did have the correct booth, I would only attempt 2 pac if I had the right area and I would make sure that I had the correct air respirator in place as the isocyanates are the things that will come back to bite you, and yes. . . they do KILL you over time. I am building a new shed to facilitate 2 pac jobs but it will have correct fans, filters and fresh air supply system for the painter.
Dave K.
PostPosted: Sun May 17, 2009 9:11 pm
This space for rent
It stuns me the number of people who will consider spraying 2K at home, because "it's only illegal if you get caught". It's illegal for a reason, the stuff is dangerous and will kill not only you, but your pets, your neighbours pets, your neighbours, etc.
Leave 2K to the pro's with extraction systems and scrubbers.
PostPosted: Sun May 17, 2009 9:16 pm
Tomboss Breweros
I just put a bit more acrylic on the roof of my clubby today and it went on near as shiney as 2K. Still i will sand and polish it to match the orange peel-less of the rest of the body.
kimini wrote:
Jimmyinamini wrote:
PostPosted: Sun May 17, 2009 9:27 pm
ditto . . . do a google search on "isocyanates paint danger" and see what come up.
Dave K.
PostPosted: Sun May 17, 2009 9:34 pm
sorry, I should clarify! "It is only illegal if you get caught" goes for all painting! enamel, acrylic, and 2pak. I do not personally spray 2pak at home, hence the sujestion of a fume extractor to help filter the spray.
I never spray outside in the open, only in an enclosed environment, I always wear the appropriate safety wear, and I treat all paints the same. Dangerous for all, and the environment!
If people wish to spray at home, then go for it. I can only sujest using proper precautions as I have kids and animals as well!
As far as "its only illegal if you get caught" goes, I sometimes say things, as do many others with a little "tongue in cheek".
Sorry if I upset!
mooo, I'm a pig!
PostPosted: Sun May 17, 2009 9:36 pm
Tomboss Breweros
Generally all volatile chemicals are very dangerous in more ways than one, even that common type we all put in the back of our cars.
kimini wrote:
Jimmyinamini wrote:
PostPosted: Sun May 17, 2009 9:41 pm
I agree completely with all comments about the dangers! I spray at least 3 days of the week at work. But as I said earlier, and I am sorry again for wording it incorrectly, I never spray in the open. Including acrylic in my driveway!
mooo, I'm a pig!
