It is currently Wed Aug 13, 2025 12:07 pm
PostPosted: Tue May 19, 2009 11:12 am
yes beforgiving..otherwise we'll look at you and do it you next time :roll:
PostPosted: Tue May 19, 2009 2:57 pm
not meaning to be rude but drive an auto less pedals to get wrong
PostPosted: Tue May 19, 2009 5:35 pm
I dont think you could corner tight enough at a fast enough speed for the fluid to rush to one side of the cylinder and air to get in. And if you did take a video next time lol.
You could have a very tiny leak somewhere in the system, that only lets fluid out slowly under high pressures. eg when you hammer the pedal. But this would be a gradual pedal change.
Its a tricky one.
PostPosted: Tue May 19, 2009 6:28 pm
Its a tricky one.
If you leave the cap off the master cylinder like they did it is quite easy to get the cylinder to suck air. Once you lose half the fluid it will pick up air in a corner easily.
I would still check the whole system.
PostPosted: Thu May 21, 2009 7:16 am
hey after close inspection of my brake lines i have a slight leak not much but enought to do a difference it is the metal linking pipe at the front left hand wheel so i will change tht 2 morrow thaks guys for all your help
Users browsing this forum: No registered users and 253 guests
