It is currently Fri Aug 15, 2025 6:51 am
Forum locked This topic is locked, you cannot edit posts or make further replies.  [ 2 posts ]
PostPosted: Tue May 19, 2009 8:33 pm
This 'How To' is to help you identify what carbs you have on your car.
These are the most common forms found on minis.
When identifying your carbs, it helps to look at the pattern of the holes used to mount them to the manifold.
SU Carburetors
1-1/4" = HS2
1-1/2" = HS4
1-3/4" = HS6
1-1/2" - HIF38
1-3/4" = HIF44
1-7/8" = HS7
2" = HS8
Others
Sidedraft (common sizes- there are others)
Weber 40DCOE = 40mm twin choke
Dellorto 40DHLA = 40mm twin choke
Weber 42DCOE = 42mm twin choke
Weber 45DCOE = 45mm twin choke
Dellorto 45DHLA = 45mm twin choke
Weber 48DCOE = 48mm twin choke
Dellorto 48DHLA = 48mm twin choke
Downdraft
Nikki, 2 barrel progressive
Weber 28/36 DCD etc, 2 barrel progressive
Weber 48IDA twin choke
Carburator Dellorto fzd 32.26 nuovo per fiat 500 3
Reece Fish Carburetor - 1-1/4" or 1-1/2"
Carburettor air flow when used with an A series Engine
- From www.minispeed.co.uk
This will be Updated as we receive more Photos etc
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
PostPosted: Tue May 19, 2009 10:09 pm
Weber 48IDA (Belongs to member 1071)
Users browsing this forum: No registered users and 28 guests
