It is currently Fri Jul 18, 2025 9:59 am
PostPosted: Sat May 23, 2009 12:05 pm
Milatsmadmini
Ive got sitting in my garage a nice set of CX500 38mm carbs waiting to go anywhere (not the bin!)
id really like to be able to set them on a mini engine/head as something a little different (though someone on here has alread done so...)
So just wondering if anyone has any ideas where to get a manifold made up? not that complicated, a 1.5" pipe, welded to bottom flange, then attach carbs with silicon tubing to manifold...
Matt
PostPosted: Sat May 23, 2009 9:51 pm
So you want a manifold to go with the head as well.
OK twist my arm and give me a pic of the carby base and length overall
of the carby.
www.minisprintgt.com
PostPosted: Sun May 24, 2009 12:30 pm
Milatsmadmini
thanks David.
Ok some dimensions, full length of it is just shy of 9 1/2".
Between needles is just shy of 6 1/2" width from filter side to intake side is 4 1/2"
ball is in your court...
PostPosted: Sun May 24, 2009 12:38 pm
Milatsmadmini
thats them in situ... no real angle there... :?
