It is currently Sat Jul 19, 2025 2:08 am
PostPosted: Sun May 24, 2009 6:59 pm
Right, its time to route my brake line.
More specifically, the line that goes front to rear.
I think, at this stage, I will be running a tandem setup.
Will this make any difference in the way the line runs from front to rear?
And secondly, I'm after some pics of how it is arranged.
--- ie as it sneaks up behind the front subframe and to the master cylinder.
Rear pics would be nice too.
PostPosted: Sun May 24, 2009 7:06 pm
Page two and Three
http://www.ausmini.com/forums/viewtopic ... c&start=15
Three & Four
http://www.ausmini.com/forums/viewtopic ... c&start=30
PostPosted: Mon May 25, 2009 1:02 am
Road car or race car willy?
If race car, run it inside the car. Small hole with a grommet at each end to pass the line through. Makes it easy to fit, can't take it out on a ripple strip if you get a bit wayward.
