It is currently Sat Jul 19, 2025 7:15 am
 Post subject: Engine bulk heads
PostPosted: Sun May 24, 2009 7:21 pm
Hi
Trying to fit my twin 1.5inch carbs and i have had to tilt the engine forward to allow the float bowls to clear the bulk head. 1979 Mini LE (Nz car)
Are all bulk heads the same eg Clubman etc,
The manifold is a copy of the maniflow one. I have bad feeling the guy got the carb angle wrong or the manifold is too long..
I will go and take a pic
Kiwiinwgtn
PostPosted: Sun May 24, 2009 8:18 pm
pics
PostPosted: Sun May 24, 2009 8:25 pm
Photos didn't work.
Do you have the engine staiblisers on? I've found with out them the engine will lean back a bit.
PostPosted: Sun May 24, 2009 8:26 pm
This space for rent
PostPosted: Sun May 24, 2009 8:27 pm
Thanks Simon
How did you the pics to show..
Thanks
Kiwiinwgtn
PostPosted: Sun May 24, 2009 8:29 pm
Our firewalls are different. :wink:
PostPosted: Sun May 24, 2009 8:41 pm
I'd cut the manifold flanges off and shorten the tubes, there's too much straight pipe there before it bends up.
Pretty, though... 8)
PostPosted: Sun May 24, 2009 9:05 pm
Hi Kev
You could be right, *&^%
The problem is they may fowl my headers,
The fuse box in my garage is on the blink, so cant go and check (where's a torch)
Kiwiinwgtn
PostPosted: Sun May 24, 2009 9:11 pm
Make a new balance pipe then, curved up like the Maniflow one is.
You haven't even got room for your air filters :cry:
I didn't know that Maniflow made different lengths?
PostPosted: Sun May 24, 2009 9:12 pm
It's an UnZud copy. :wink:
PostPosted: Sun May 24, 2009 9:15 pm
ooh Okay-I just went back to find this pic.
There's heaps of room on the "genuine article" :)
PostPosted: Sun May 24, 2009 9:47 pm
back from the freezer..
Yep need to move the whole manifold in 8-10mm,
:cry: :cry: :cry: :cry: :cry:
PostPosted: Sun May 24, 2009 9:57 pm
Filters fit fine, its the float bowls that are just hitting the bulk head
Yes its custom made :lol:
PostPosted: Sun May 24, 2009 10:34 pm
Can you have the flanges machined to cause the carbs to point up a smidge more?
Users browsing this forum: Bing [Bot] and 77 guests
