IwannaMini wrote:
is this the same diagnostic for similar issue but forwards? My Rover is slipping going fowards AND backwards.... Only seems to happen though in the first say 5 mins of driving. After that, doesnt seem to be any issue. I always warm her up until the heat guage moves to the white line in the middle too... so she isnt cold....
She is going in to see "Uncle Malure" tomorrow morning but its always nice to know what I am in for...
Black book auto manual says
"slip or no drive in all gears = items 7,8,13,20, 23"
7 = oil level
8 = carry out pressure check (at plug on filter housing)
13 = remove and clean valve block
20 = check oil pump, flow valve, oil supply and feed pipe seals, main oil strainer.
23 = check low pressure valve.
If it's only doing it when cold, I'd suspect the oil might be a bit thick- what grade are you running?
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
