It is currently Wed Jul 23, 2025 8:07 pm
 Post subject: Strange squeaking...
PostPosted: Wed May 27, 2009 9:31 am
so i'm driving last night and i hear this strange strange squeaking coming from what seems like the driver's side front wheel. can only really hear it when the window is open. can't feel anything through the steering wheel, no body shudder, and only happens when the wheels are straight (i did some swerving, the squeaking stops when the wheels are turning)
i'm reluctant to drive until this is fixed, i have a feeling it is the wheel bearing that has shat itself. i won't be able to test this for a couple of days though.
the squeak sounds kinda like that typical ford suspension noise, but is sorta constant.
what the crap is it???
78 Leyland Mini - Prince
PostPosted: Wed May 27, 2009 10:02 am
Tomboss Breweros
Does it have front drums?
A worn bearing could be letting the drum contact the brake backing plate.
kimini wrote:
Jimmyinamini wrote:
PostPosted: Wed May 27, 2009 10:07 am
yeah drums all round. your theory seems reasonable
PostPosted: Wed May 27, 2009 10:24 am
Knuckle joint?
Does it vary with speed? As in, the faster the wheel rotates, the frequency of the occurance of the noise increases?
Is it more or less noticable under braking?
PostPosted: Wed May 27, 2009 10:54 am
no difference when braking
it is sortof a constant noise, but as the engine noice increases in decibels, the squeak becomes harder to hear... :S
PostPosted: Wed May 27, 2009 11:07 am
ginger ninja
ginger ninja
ausmini hamster caught in your wheel? :P
sports850 wrote:
PostPosted: Wed May 27, 2009 11:23 am
Shocker?
PostPosted: Wed May 27, 2009 11:30 am
worn bearing for sure. Its on its way out, ready to crap itself completely :)
PostPosted: Wed May 27, 2009 11:42 am
I had squeaking in my rear wheel once, it turned out to be that i didnt do the wheel nuts up tight :oops:
other than that my mechanical skills limited :D
PostPosted: Wed May 27, 2009 1:08 pm
ok so what is the rule for wheel bearings? do you do one side (left/right) or one half (front/back) at the same time?
or, i could just do all four...
i'll check the wheel nuts first though :lol:
PostPosted: Wed May 27, 2009 1:39 pm
Tomboss Breweros
I do whatever bearing is gone and leave the rest :wink:
Teeth tight isn't enough, use a wheel brace :mrgreen:
kimini wrote:
Jimmyinamini wrote:
PostPosted: Wed May 27, 2009 3:12 pm
Replace the lot and get a disc brake kit.
PostPosted: Wed May 27, 2009 4:50 pm
i was going to say a mouse! :lol: :lol: :lol: :roll:
Have a Nice Day.
PostPosted: Thu May 28, 2009 12:03 am
does it get louder when you load a certain side up e.g when you turn left is it louder then when you turn right?
PostPosted: Thu May 28, 2009 8:03 am
i had similar noise in my front left so i puled split pin out of wheel bearing did it up a bit tighter put pin back in and it went away :) but wheel bearing for sure or something to do with the wheel bearing lol
Users browsing this forum: Bing [Bot], Majestic-12 [Bot] and 104 guests
