It is currently Sat Aug 23, 2025 6:25 pm
 Post subject: quick question
PostPosted: Thu May 28, 2009 2:16 pm
just wondering as to weather u know if Cooper S Hardy Spicer inner CV joints will fit on a car that has the rubber uni joints. i.e. are they interchangable on all cars, with out modifing anything?.
or
if u can and u need to change/ modify something what is required to do so ??
fiji
PostPosted: Thu May 28, 2009 2:44 pm
Hi fiji,
The diff would need to come out (engine out) to replace the two side-gears/shafts as the are bigger in diameter. The bushes in the housing and seals are larger too.
Regards
Al
PostPosted: Thu May 28, 2009 4:18 pm
It`s an engine out job Matty
final drive covers, inner axles, seals are all different,
But yes it`s all interchangable... & only takes about 4 or 5 hours :-)
PostPosted: Thu May 28, 2009 4:21 pm
BAH, they always made things easy didn't they.
:D
go the sig
Users browsing this forum: No registered users and 151 guests
