It is currently Sat Jul 19, 2025 4:37 pm
PostPosted: Tue Jun 02, 2009 10:45 am
Hi, I have a problem with my 1275 engine. The starter motor haven' t the power to turn the engine, in first instance I think that the starter motor is the problem, but I have discard this idea because I check all the electric connection and the starter motor has bee repaired recently.
The engine have starlet piston (72 mm), connecting rod lightened and flywheel lightened. The RC is 10.5.....
My question is what it happened that the engine is so tightened to turn it?
thanks and zorry for my english
Nicolás Sepúlveda-Chile
PostPosted: Tue Jun 02, 2009 11:42 am
frat brattery ?
blokeinamoke wrote:
PostPosted: Tue Jun 02, 2009 11:43 am
Has it worked previously?
If it has, I would be checking all the connections. Specifically at the battery terminal, might be a poor connection here or at the starter motor.
2008 Prado GXL
PostPosted: Tue Jun 02, 2009 11:53 am
Is it blue?
PostPosted: Tue Jun 02, 2009 12:39 pm
mini-dunger wrote:
frat brattery ?
no, the battery is new......
PostPosted: Tue Jun 02, 2009 12:47 pm
It worked previously, and I checked outside the starter motor and work very well, inclusively I put another starter motor and don`t work too...
All the connections are ok...I checked the starter motor making contact directly to the batery and nothing....it try, but it is like the engine is too tightened....I think it could be that the flywheel are deformed or a connecting rod is the problem.....
PostPosted: Tue Jun 02, 2009 12:48 pm
blokeinamoke wrote:
Is it blue?
PostPosted: Tue Jun 02, 2009 1:20 pm
Disconnect the battery and try turning it by hand using the fan belt if you cant do this then take out the spark plugs and try
PostPosted: Tue Jun 02, 2009 1:33 pm
I try to turn with the fan belt but I cant not turn it...it feels "heavy", even without the spark plugs
PostPosted: Tue Jun 02, 2009 2:09 pm
you wouldn`t have happened to have just replaced your slave cyl , or had it overhauled by any chance,???
,, sometimes people like to replace bolts when they do some jobs & if you accidently put longer bolts in there then they may be interfering with the ring gear
just a thought :-)
we would probably need a little story of the life of your car & it`s recent repairs ,& maintenance & happenings to be able to shed any more light on your problem
No funny/weired noises lately?
no funny strange grabby/chunky "feeling" through the car on the last few drives?
PostPosted: Tue Jun 02, 2009 10:29 pm
what is the condition of the earth lead from the engine to the body, and from the battery to the body? -
is the bolt tight, is the thread clean?
PostPosted: Tue Jun 02, 2009 10:50 pm
just a thought :-)
the engine was re-building about 5 months back, it was put a starlet piston (72 mm), lightened the flywheel and connecting rod and the head was upgrade with bigger valve. The RC in firts place was 11,5:1.
Lately have a metalic noises and become to throw smoke...
I think that the better idea is dismantle the engine and check inside...
Thanks...
PostPosted: Tue Jun 02, 2009 10:52 pm
the earth lead from the engine is in good condition, they have two earth lead and the earth lead from the battery to the body is good, clean and the bolt tight.
Thanks.
PostPosted: Wed Jun 03, 2009 8:13 am
just a thought :-)
Thanks...
that doesnt sound good :shock:
PostPosted: Wed Jun 03, 2009 7:39 pm
blokeinamoke wrote:
just a thought :-)
Thanks...
:? Is that your professional opinion BIAM or are you just guessing.................................................. again :?: :wink:
