It is currently Wed Aug 13, 2025 4:18 pm
 Post subject: Washer bottles.
PostPosted: Sat Jun 13, 2009 4:43 pm
lame question i know. :oops:
I'm just a bit lost with this.
i would like to use a electric one or a pump at least I'm' running out of room to fit a aftermarket one with a pump.
i don't really know how the original even worked, did it have a pump for the Windscreen washer squirters ?
Do i just attach a small aftermarket electric pump to the original bottle? from super cheap?
thanks for your help.
something like this below with an aftermarket pump?
is this what you guys do?
http://www.minisport.com.au/prod723.htm
PostPosted: Sat Jun 13, 2009 4:45 pm
The thing behind the dash is a pump. You pump it manually.
Go buy a kit, you get a new bottle, leccy pump, switch and all. Mount it on the drivers side inner guard if you don't have a booster.
PostPosted: Sat Jun 13, 2009 4:48 pm
i have a booster! & Aircon.
& the Kitchen sink.
PostPosted: Sat Jun 13, 2009 4:50 pm
You'll find somewhere to mount it haha
yeah they are very easy to fit and if your not worried about "concourse perfection" they are alot better.. mine is just mounted on the inner gaurd still a bit or room in there :P
Potato
PostPosted: Sat Jun 13, 2009 5:00 pm
i bought the same one you have. but the sink & aircon sits there lol.
i don't think it's gonna fit. i guess ill just wait & see when i put the booster & Aircon back in see what space i have left.
:shock:
PostPosted: Sat Jun 13, 2009 5:01 pm
the black plate to the left. or drivers side. where fresh heater pipe intake would be
where did you buy that?
I'm looking for one & with a hole in it like that would be perfect!
PostPosted: Sat Jun 13, 2009 5:12 pm
i made it out of aluminium plate then just holesawed a chunk out of it.. pretty simple to do
Potato
PostPosted: Sat Jun 13, 2009 5:20 pm
Rover Cooper
Mine is fitted in the boot on the drivers side, because I also have a kitchen sink under the bonnet, not that hard to run a 1/4 or 1/8 inch tube through from the back to the front and its easy to operate as well. Don't have to go too far for the power connection either about 6 inches........
PostPosted: Sat Jun 13, 2009 5:26 pm
I have a Toyota washer bottle and pump in under the LH guard. Also a pair of metal trumpet Fiamm air horns in there too.
PostPosted: Sat Jun 13, 2009 5:27 pm
Rover Cooper
No loss of pressure over the extra distance either. :wink: :wink:
PostPosted: Sat Jun 13, 2009 6:03 pm
Ive got mine in the same spot dr mini has, Ita a d22 navara one with a long bent neck so its easy to fill
PostPosted: Sat Jun 13, 2009 6:58 pm
Standard washer bottle with electric pump to the right of the radiator cap in the photo.
PostPosted: Sat Jun 13, 2009 7:04 pm
Damn straight! I was using one of those pumps for another project and found that it was able to supply 14 psi....not bad for a crummy little pump I thought.
PostPosted: Sat Jun 13, 2009 9:01 pm
it all looks very normal in there, until you spot the extra clutch MC!
Users browsing this forum: Bing [Bot] and 258 guests
