It is currently Sat Aug 02, 2025 9:09 am
PostPosted: Mon Jun 15, 2009 2:26 pm
can people let me know what temp they have there minis running at when it gets warm?
PostPosted: Mon Jun 15, 2009 2:30 pm
82 C, but that is with a race thermostat. You should be looking around 90 C
Please ask the question in your title.
PostPosted: Mon Jun 15, 2009 2:32 pm
its getting to about 70C.
PostPosted: Mon Jun 15, 2009 2:35 pm
I is a mookenik
its better then mine... going around 100-110
PostPosted: Mon Jun 15, 2009 2:53 pm
Location: Burpengary,Brisbane Nth(the better side of Bribane)
Mines only around that also, so I just ordered a 88deg thermostat, hope that helps because IMO 70deg is to low...
https://t.me/pump_upp
PostPosted: Mon Jun 15, 2009 2:55 pm
Mine sits between 80 and 90 degrees C with an 82 degree thermostat in it.
Do you know what thermostat you have in your car or if it does have one at all?
PostPosted: Mon Jun 15, 2009 3:21 pm
110 is a bit hot, check your timing, retarded dizzy can cause it to get hot.
check your thermostat isnt getting stuck open, put it into boiling water from the kettle and slowly add cool water with a thermometer in the water and see what temp it closes at.
should open at the rated temp and close not far below it.
PostPosted: Mon Jun 15, 2009 5:18 pm
92 degrees and steady with a 90 degree thermostat.
PostPosted: Mon Jun 15, 2009 5:33 pm
its Tinys - of courese its retarded :P
PostPosted: Mon Jun 15, 2009 5:34 pm
I is a mookenik
lol nah the radiators about 70% blocked so i gotta get it cleaned out asap.
PostPosted: Mon Jun 15, 2009 5:48 pm
Mine sits halfway between E and M. :mrgreen:
I have blocked the grill completely to see if I can get it to run better when it is -6°. It does not seem to make any difference to hot running but it seems to help cold running.
PostPosted: Mon Jun 15, 2009 6:09 pm
atm with this cold weather its getting hard to get to 90 even during the day , but when summer was here i was getting about 80- 100 C. 100 only when siting or hard run to the coast on motorway it would creep up.
PostPosted: Mon Jun 15, 2009 6:13 pm
This space for rent
About 90*C with an 88*C thermostat installed... and running better than it was with the 82*C thermo.
PostPosted: Mon Jun 15, 2009 7:40 pm
i just got one from minisport i think it could be a 74oC
PostPosted: Mon Jun 15, 2009 8:00 pm
This winter I hardly see 40-50 degrees... (1/4 guage, 10 minute trip to work) :(
But normally 87
Lillee - 1969 Morris Mini K
Users browsing this forum: Bing [Bot] and 80 guests
