It is currently Sun Aug 03, 2025 2:54 am
PostPosted: Wed Jun 17, 2009 7:04 am
i mounted mine on a piece of flat steel..steel bolted to rear sub frame..and i used tiny rubber mounts...think there exhaust mounts...was told its the way to reduce viberation and noise..
PostPosted: Wed Jun 17, 2009 2:45 pm
superSeven wrote:
I like the ticking.. became part of the start-up procedure! was good to know the fuel pump was still working!
key in ignition
listen for clicking - check
prime carby - pump accelerator twice
press starter button
let all hell break loose.
Someone should start a poll.....put me down in favour of the tick
My first introduction to SU pumps was with an old 1960
MkII Jag. I too became endeared with the ticking.
The car had a push button and the carbys had an enricher (no choke).
So I was quite pleased that me little MG 1100 had a SU pump,
might even install a little start push button. Forget the enricher
Converting the points to transister is the go. Cheap too.
Still get the comforting ticking sound.
Plans are on the net.
PostPosted: Wed Jun 17, 2009 2:53 pm
tick-squish-tick-squish-tick-squish-tick-squish-tick-squish-tick-squish-
PostPosted: Wed Jun 17, 2009 3:40 pm
ginger ninja
ginger ninja
deleted blonde comment... should have read full post first :oops:
sports850 wrote:
PostPosted: Wed Jun 17, 2009 3:45 pm
swae85 wrote:
I dont hear anything :shock: Is that a bad omen?
no, they're discussing electric fuel pumps, you've got a mechanical one that is attached to the motor, no ticking
PostPosted: Wed Jun 17, 2009 3:50 pm
Yeah do use exhaust mounts, but those little rear ones are too stiff.
Use the big square centre zorst mount- the 2 bolt holes line up with the pump. :D
BTW the pump is supposed to be on a 45° angle by their book (but yeah they do work OK horizontal)
PostPosted: Wed Jun 17, 2009 3:53 pm
my son's Clubby (Satan's Rollerskate) had a Facet pump on the firewall - damn near drove me mad, you could hear it over the exhaust - in fact it was the only thing you could hear over the exhaust :wink:
'62 Morris 850 (Marion)
'69 Vanden Plas Princess 1300
'71 Wolseley 1300
'74 Austin 1300 Countryman
'94 XJ6 Sport 3.2
'04 Rover 75 CDTi
PostPosted: Thu Jun 18, 2009 12:23 pm
gafmo wrote:
Complaining about a Ticking sound :roll: at least you would know when you have ran out of petrol
One tick on start up.
Otherwise turn your Music up :lol:
These pumps need to be situated below the tank don't they :?: I reckon if you ran out of petrol in this one you would have to put over half a tank full in it to get it going.
PostPosted: Thu Jun 18, 2009 12:50 pm
On my MG 1100 it's actually in the boot at the top of the tank.
But the intake pipe would naturally have to be directed to bottom
of the tank.
PostPosted: Thu Jun 18, 2009 12:52 pm
Do mean 45 degrees from the inlet to the outlet?
Can they be mounted and work OK upside down? (have seen this done a few times)
Also - I notice that the Facet have a filter on the inlet brass thing - is this neccessary or can you just use a plain ryco one on the rubber fuel line coming into the pump and not have one up near the carby - or would you use 2?
Dave K.
PostPosted: Thu Jun 18, 2009 7:10 pm
Facet say you should have an intake filter of some sort. There is a gauze in the tank, unless you've relined the tank and then had to bash a hole through the strainer. I did this with my RH tank, then put a Ryco filter there. So far, so good.
If running SUs, no other filter is needed if you have a strainer. With a Weber or Dellorto I add a Purolator glass filter up near the carby.
Don't use these filters under the car, if a rock hits it you will be up the creek. :cry:
