It is currently Fri Aug 01, 2025 9:32 pm
Post new topic Reply to topic  [ 20 posts ]  Go to page Previous  1, 2
PostPosted: Wed Jun 17, 2009 9:42 pm
jimmyinamini wrote:
Gadgets mini wrote:
check the headlight fluid it might be getting low :wink:
probably best to drain and refil with the more expensive halogen fluid. :idea:
He needs the Light stuff
David L
PostPosted: Wed Jun 17, 2009 10:30 pm
Cos it's got a higher flash point.
PostPosted: Thu Jun 18, 2009 12:34 am
Supercharged
poeee wrote:
It's a Clubman... so being a Clubman, it means it's the switch.
i say switch also, as once in a blue moon it happens on my clubby.
i am not certain, but you possibly will not be able to use a different switch to test it as you might need a specific two stage headlight switch.
luckily these are available NEW but not cheap from places like minisport who could post it out to you express or you can get one s/h from somewhere.
PostPosted: Thu Jun 18, 2009 7:03 pm
AEG163job wrote:
my$20 is on a faulty earth.
I think that you may be on a winner. :wink:
Everyone is only concerned with getting a lot of power to the globe and they all forget the black wire.
I had a similar problem on my F100 (but only one headlight due to the way it was wired) Dust behind a dodgy earth connection. Once you got the light to come on it would stay on.
PostPosted: Thu Jun 18, 2009 7:06 pm
Ahem... :P
Mick wrote:
and common connection points for the low and high beam (like in the center of the bonnet catch panel) including the black ground wires.
Users browsing this forum: Phil 850 and 83 guests
