It is currently Thu Aug 07, 2025 6:36 pm
 Post subject: My Reco Head Pics
PostPosted: Thu Jun 18, 2009 6:42 pm
this 12g940 head has had a port and polish,
1.40" inlet valves
hardened valve seats on exhaust side, and new double valve springs
and chambers reshaped and cc
the finish is so good i don't know if i should paint or leave it
77 Leyland Clubman
1293cc, LCB extractors, pulsar dizzy (recurved), cooper s disc brakes, 40DCOE Weber
PostPosted: Thu Jun 18, 2009 6:58 pm
oh man that looks tasty.....mmm....droool
PostPosted: Thu Jun 18, 2009 7:03 pm
It's a little sad after all that work, we go and bolt them on....all the pretty stuff is now on the inside, and will get covered in soot!
 Post subject: Port and Polish !
PostPosted: Thu Jun 18, 2009 8:23 pm
That looks like the ports have not been touched only the chambers are cleaned up. Looks good though.
"Let us remove your "SHORTS"
PostPosted: Thu Jun 18, 2009 8:29 pm
its hard to see with the valves in but its all been opened up a little, and cleaned up nice and smooth, its not a extreme port, if only i had the before photos intake and exhaust ports where heaps smaller than the manifold gasket, now they are the same size as the gasket openings,
i guess every head seams to be cast a little different, i may have had a real bad one
77 Leyland Clubman
PostPosted: Thu Jun 18, 2009 9:02 pm
my god that looks good! :shock:
I'd put a sheet of glass over the top and use it as a (very)small coffee table!!
Skender.
PostPosted: Thu Jun 18, 2009 9:06 pm
This space for rent
Surely you're not going to ruin that head by bolting it onto an engine!?
Another example where they didn't come out of the factory looking that good 8)
PostPosted: Thu Jun 18, 2009 9:11 pm
72...Love it :wink:
PostPosted: Thu Jun 18, 2009 9:36 pm
That does look nice and its the next thing to get done to the moke,
Who did the work and roughly what did it cost?
PostPosted: Thu Jun 18, 2009 9:56 pm
Nice clean mild head, well done,,, it`s often not much point opening the ports up much for a roady,,, & often quite detrimental (depending) the biggest restriction is at the valve & seat area,,, std-ish ports are are just fine for most road/rally minis
Nice job
But yes paint it right now as they go rusty very quick
PostPosted: Fri Jun 19, 2009 11:13 am
Very nice, I might ask you one day where you got that done.
Flute - 68 MK I Cooper S
Member: VMCI #2474
PostPosted: Fri Jun 19, 2009 11:25 am
yea it was a top job, i am a little worried about the chambers being 22cc, means i may end up with a final compression of around 10.5:1
which i dont know if that would even run properly unless on avgas
77 Leyland Clubman
PostPosted: Fri Jun 19, 2009 12:41 pm
I run 10.5:1. Runs fine on 95, but better on 98
PostPosted: Fri Jun 19, 2009 8:30 pm
10.5 will be no troubles I'd hate to think what my 202 head mega skim on a 1152 is :lol:
PostPosted: Fri Jun 19, 2009 8:32 pm
Well it all depends what cam you use. The more duration it has, the higher C/R you can run.
With a stock cam, it would ping its head off (pun intended) on 95.
The Cooper S was 9.75:1 stock, and they were not real happy on 97 octane leaded Super.
