david rosenthal wrote:
I looking at buying a "cooper s"????? eng. It has the extra head studs, but what other engs[ie capacity] had extra studs. This block has the fuel p/p hole blanked off as part of the casting and tappet covers. the head is a 12G940 and has double v/v springs and cast/forged ?? rocker arms.
The block has NO serial numbers stamped on it.
the rocker arms are normal for a cooper S - forged/cast, not pressed steel
12G940 head is a MK2 head
have a look at the flange - if it's about 5/16" thick it's a MK1 block, if it's about 1/2" think it's a MK2
The box has uni drives and the No's on it are 22G1128 and 214270. It has a "reverse light switch"???? in the front casing. Remote shift type
22G1128 is right for a MK2 gearbox, but could also be a mini K. If it has stampings starting with 9f on the flat part at the drivers side of the front, opposite where the 22G1128 is, then it's likely to be from an S. The fact that it's got hardie spicers means it's even more likely to be an S - no real way of knowing till you look at the stampings on the laygear
did I tell you that I won a
trophy?
