It is currently Tue Aug 05, 2025 9:38 pm
PostPosted: Fri Jun 19, 2009 11:37 am
Hey guys.
I have everything of the mini the mini it's pretty much ready to come out.
i just need to pop out the pin on the back of the engine & take extractors of the exhaust.
can anyone help me? take it out & load it onto my mates Ute.
i don't have a engine crane.
there is a carton of bear or a cool $50 in it for yah.
I'm just on the Northside
Brisbane. boondall.
0415 537 117
thanks
Nick Galea
PostPosted: Fri Jun 19, 2009 12:47 pm
Don't get home till 7 tonight and can't make it tomorrow as I'm leaving at 7am for the Sunshine Coast - and won't be back till night. Can help Sunday afternoon it it's any help. Be a bit difficult without a hoist - do you have an overhead attatchment opoint for a hand winch?
David L
PostPosted: Fri Jun 19, 2009 12:50 pm
hey wombat.
i don't have anything handy to pull it out.
there is a bracket you can use to pull the engine out right?
i don't have that either.
PostPosted: Fri Jun 19, 2009 12:55 pm
You can use an engine crane, chain and tackle or drop out the subframe and lift the body over the engine. Your choice. Glad I don't have to do it lol.
DO IT ONCE, DO IT RIGHT
PostPosted: Fri Jun 19, 2009 12:57 pm
hehe.
no it's easy! just out the top. every thing is off to pull it out.
PostPosted: Fri Jun 19, 2009 1:14 pm
No - dont lift it out by hand - its 300 kg (or what ever ??) and bending and lifting not only does damages to backs its also leads to people struggling and body panels getting damaged.
Go and hire an engine crane from a hire place or a mate. You will only need it for an hour if everything is truely undone.
Think this one through sensibly
Mike
PostPosted: Fri Jun 19, 2009 1:22 pm
yeh. stuff trying to pick it up.
yeh can go hire a crane, i just don't have anything to hook it onto the engine.
instead was hoping a mini lad would be near me give me a hand.
the rad is still on there is few Cm of clearance that can stay on right?
PostPosted: Fri Jun 19, 2009 1:45 pm
Just get a small lenght of (strong) chain - about a foot is all you need. Find the centre forward facing head stud. The go to the ones either side of it and undo the bolts - slip the chain under the bolt and washer on each of those and do the bolts up so they wont slip undone.
Its not perfect but the motor will hang in about the right position to clear everything. Make sure you dont forget the earth cable to the body from the gearbox and dont forget to undo the speedo cable as you can get to as the engine lifts.
Mike
PostPosted: Fri Jun 19, 2009 3:55 pm
Location: Burpengary,Brisbane Nth(the better side of Bribane)
Ive got a block & tackle (endless chain) and a bracket if you want a lend of it , but you will need a beam on something to hang it off. I'm in burpengary if that helps.
https://t.me/pump_upp
PostPosted: Fri Jun 19, 2009 5:49 pm
prob bit to far for me.. cheers though mate.
i might have to just hire one my self. it's only $60.
i just don't have the engine bracket.
PostPosted: Fri Jun 19, 2009 5:57 pm
find a piece of 5mm right angled metal and drill 2 holes in it. 1 for the head stud and the other for the D-shackle. then use mr. lifto to remove the engine
PostPosted: Fri Jun 19, 2009 6:18 pm
where did you get that idea?? :lol: :lol: :lol: :lol:
PostPosted: Fri Jun 19, 2009 6:19 pm
dunno but it worked a treat...cheers :D
PostPosted: Fri Jun 19, 2009 7:58 pm
Have you found anyone with a crane yet?
PostPosted: Fri Jun 19, 2009 9:03 pm
not yet mate, everything is ready to come out.
i just don't know how to get the pin out of the rod Change & i cant seem to pull the extractors of the exhaust.
apart from that it is all undone ready to pull out.
if anyone cant help me i can hire one it's not biggy lads :)
