It is currently Sat Jul 19, 2025 3:28 am
Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
PostPosted: Mon Jun 22, 2009 7:44 pm
There are quality layshafts available with the followings specs;
EN36T steel
Case hardened all over by a special process
Rockwell hardness of 64.
Made in the UK by a specialist gear company.
Hope this helps. :D
PostPosted: Mon Jun 22, 2009 8:50 pm
EN36T steel
Hope this helps. :D
that is very useful information ;)
I spoke to my toolmaker friend today and he agreed with the idea of using a bush, and then he went into all the different bushing materials we could use and settled on a work hardening something or other - I think I'll be talking him into making me some bushes
PostPosted: Mon Jun 22, 2009 9:11 pm
Just a question on the oil feed line . wouldn"t you have to seal the cluster gear to maintane oil pressure ? other wise it would be like breaking the oil pipe to your gauge, easy way out , reduced oil pressure to every where else ???????
PostPosted: Mon Jun 22, 2009 9:17 pm
No, you would put a restrictor jet in the feed line, same as for a turbo oil feed.
PostPosted: Mon Jun 22, 2009 9:43 pm
Thanks doc , restrict the pressure before it enters the cluster ?
PostPosted: Mon Jun 22, 2009 10:21 pm
Yes. you don't need much pressure there, for roller bearings anyway.
As for how much oil feed with bushes there, I dunno.
pros- reverse gear has a bush and it seems to last OK.
cons- BMC got rid of bushes on the mainshaft in 1963/64, after failures in competition use. I seem to remember the problem was they broke up or seized.
I have heard that shady gearbox reconditioners (read: wreckers) years ago used to recondition Holden boxes by fitting layshaft bushes. Cheaper than buying bearings. :lol:
PostPosted: Thu Jul 09, 2009 8:03 pm
Swiftune sells a purpose made layshaft(s???) for customers who run their wonderful dog gearsets that are made by Quaife. This layshaft(s) are made of a hard steel with a high RC number. Swiftune did not want any of their customers to experience gearbox failure because of installing their excellent Quaife gearsets with customer layshafts of unknown quality. Not sure if these improved layshafts are available for remote shift sets.
Users browsing this forum: No registered users and 26 guests
