It is currently Fri Jul 18, 2025 11:35 pm
Post new topic Reply to topic  [ 113 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 8  Next
PostPosted: Thu Mar 03, 2005 1:36 pm
Dead Standard- Worn out CLubbie Rod-Change....
not even a comp diff pin....
I just dont dumpt it or thrash the arse out of it...
I've also got two spare boxes .. but this one has seen daily driving, track work, freeway and dyno time... crunches into second, but it did that before the turbo came along !
Made them good back then, they did....
J
PostPosted: Thu Mar 03, 2005 1:50 pm
Check out http://www.freewebs.com/kyoda/ourminis.htm (scroll down a bit until you get to the Cooper S), for all the specs and setup for the turbo on our Mini.
Julie.............
PostPosted: Thu Mar 03, 2005 2:05 pm
so neat :)
PostPosted: Thu Mar 03, 2005 3:06 pm
you might wanna look at getting some good rubber under your guards :lol:
BRICKWORX RACING
872-874 South Rd
Edwardstown
SA 5039
PH: 8297 9494
FAX: 8297 7133
PostPosted: Thu Mar 03, 2005 5:15 pm
Its official.. the Horsepower wars are now on... Small Block Honor to uphold here...
New turbo is an IHI RHF-5 (VJ26) - a fair bit larger on the compressor size than my dinky RHB-4 and it has a ball-bearing centre....
Just have to make a new manifold now....
so, any offers for the existing manifold and turbo ? - Will be coming off in the next 2-3 months.. have to build the other one first!
Later
J
PostPosted: Thu Mar 03, 2005 6:21 pm
nice james,,,, where did you pick that up? is that of the subaru RS Legacy, mazda familiar or isuzu diesel????
Looks like i may have to upgrade my turbo for more power too,,, had a good look at my dyno graph today and the boost was set on 14.7psi (1 bar) it hit 14psi at 120hp then dropped of to 12psi all the way to 152hp.....
Ill be looking for a second hand gt25r ballbearing version of my turbo (t25g silvia turbo) soon,, should hold boost better and come on earlier too.
1974 Moke - 998cc
PostPosted: Thu Mar 03, 2005 7:02 pm
keen on turbo set up :!:
BRICKWORX RACING
872-874 South Rd
Edwardstown
SA 5039
PH: 8297 9494
FAX: 8297 7133
PostPosted: Thu Mar 03, 2005 7:12 pm
ill fight you for it :x
PostPosted: Thu Mar 03, 2005 7:50 pm
ill out bid you :lol:
BRICKWORX RACING
872-874 South Rd
Edwardstown
SA 5039
PH: 8297 9494
FAX: 8297 7133
 Post subject: turbo
PostPosted: Fri Mar 04, 2005 6:23 am
j im just gonna come round ur house one day and steel ur old turbo set up hahaha u know i want one
PostPosted: Fri Mar 04, 2005 7:50 am
Im in the process of going a budget (really Budget) turbo setup on my mini.
At the moment it looks like Im going to run a suck through system with a pulsar T2 and 1.75 inch carby.
Ive got the bonnet off and it seems the turbo can fit behind the head where the carby sits and the the carby will be moved to the inlet side of the turbo. My plans are to use a V clamp flange for it like a mate has on his twin turbo falcon.
My standard exhaust already has this the the exhaust manifold will be modified to face towards the sky and the turbo will be V clamped to the outlet of that.
Im picking up a Datsun twin SU setup on the weekend for $50. Woot! If it isnt enough fuel which it should be Im probably going to run another fuel line and a high pressure pump and put an Injector behind the carby and hobbs switch to run at 3 psi or so.
PostPosted: Fri Mar 04, 2005 10:45 am
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
dan have a look at kazjims set up very agricultral but who gives a rats arse it gets 74 +hp at the wheels
makka
PostPosted: Fri Mar 04, 2005 10:46 am
Don't you already have trouble keeping head gaskets up to the 998 kazjim? Or am I thinking of someone else?
PostPosted: Fri Mar 04, 2005 11:33 am
Yes he did blow Payen copper gaskets (so did a few others) until they switched to using ACL's CP250MT ones.
These things are built similar to a BK450 (1275) turbo gasket- no problems since. :wink:
PostPosted: Fri Mar 04, 2005 11:58 am
Kev, was going to say that....
ACL....not a problem yet !
J
Users browsing this forum: No registered users and 26 guests
