It is currently Fri Jul 18, 2025 10:11 pm
 Post subject: Webber vs SU carbies
PostPosted: Wed Jun 24, 2009 7:01 pm
May be a really dumb questions, however what are the pro's and con's of the 2 kinds of carbies?
It's not the size of the dog in the fight, but the size of the fight in the dog!!
1976 Mini SS
1971 Mini Ute (Custom) - really hubby's but I will claim half :)
1976 Mini SS Shell
Oh and an 850 shell waiting for our dear son to start his resto!
PostPosted: Wed Jun 24, 2009 7:18 pm
SU:
Pros-
Good economy. Can provide vacuum advance to dizzy.
Quieter.
Good emissions.
Good low speed and midrange torque.
Cons-
Getting the right needle selected, there are something like 800 now.
Throttle shafts wear eventually (on HS series) and give air leaks.
Needles rub on the jet (floating needle types)- can wear both badly in 20,000km.
Harder to tune, ie not many dyno places speak SU.
With twin setups, linkage can wear, putting them out of balance with each other.
Weber DCOE or Dellorto DHLA:
Pros-
Better top end power (usually).
The NOISE.
Once tuned they stay tuned. Both barrels are synchronised on a single shaft.
Throttle shaft has ball bearings and seals.
Better throttle response over 3000rpm.
Very tuneable, heaps of jets etc available.
Cons-
Poorer fuel economy.
Poor emissions.
Bad choice for a city driver, due to poor low speed throttle response.
Difficult to fit into a Mini on a decent manifold (for high power) without cutting firewall.
You pays your $$$, and makes your choice.:mrgreen:
PostPosted: Wed Jun 24, 2009 7:20 pm
SU:
Pros-
Quieter.
Good emissions.
Cons-
Pros-
The NOISE.
Cons-
Poor emissions.
Thanks! :)
1976 Mini SS
1976 Mini SS Shell
PostPosted: Wed Jun 24, 2009 7:34 pm
SU:
Pros-
Quieter.
Good emissions.
Cons-
Pros-
The NOISE.
Once tuned they stay tuned. Both barrels are synchronised on a single shaft.Throttle shaft has ball bearings and seals.
Cons-
Poor emissions.
Just thinking aloud again , would it be possible to make a single shaft for twin SU's , I know it would involve a lot of fiddling to make sure both carbs were set up in line but it could help in tuning ????
PostPosted: Wed Jun 24, 2009 7:38 pm
sports850 wrote:
SU:
Pros-
Quieter.
Good emissions.
Cons-
Pros-
The NOISE.
Cons-
Poor emissions.
It would be possible but thermal expansion and other things would affect it. The Stock BMC way works as long as the operator knows what he is doing when he sets it up.
The Warneford way with the W clip that was fitted to the Sports 850 and the BMC Hot Up Kits is probably a good enough solution.
PostPosted: Wed Jun 24, 2009 7:41 pm
Anything is possible. The problem with 1 shaft and 2 carb bodies is synchronising the idle, I would say.
Early twin setups like your 850 Sport had 1 shaft. OK, so it was 3 bits joined by W-clips.. :lol:
The Cooper & S 3 piece shaft setup is OK and works well with all new bits, unfortunately the bits do wear with time.
PostPosted: Wed Jun 24, 2009 8:00 pm
go the weber, love the noise and there is also the noise
PostPosted: Wed Jun 24, 2009 9:24 pm
and what about that noise?! :lol:
PostPosted: Wed Jun 24, 2009 9:39 pm
This space for rent
As you can probably guess, Doc is a Weber fan ;)
I'm impressed by the design of the SU, it dates back to the early 1900's and hasn't changed much in that time because it works so well. There are shortcomings as Doc described, but IMHO they're outweighed by the ability for the average owner-mechanic to understand how the thing works set up for their car. It usually takes dyno time to get a Weber properly dialled in, and while it can benefit an SU too, generally you can get by without.
On the other hand, I can't for the life of me figure out the HS4 on my clubby van.. so there's two sides to the story :lol:
Users browsing this forum: No registered users and 114 guests
