It is currently Sat Aug 23, 2025 10:05 am
Post new topic Reply to topic  [ 66 posts ]  Go to page Previous  1, 2, 3, 4, 5
PostPosted: Mon Jun 22, 2009 7:04 pm
They're not actually Tek screws, they're what we refer to as cladding screws.
But the sheeties still use tek guns to screw them in with using a phillips bit.
PostPosted: Mon Jun 22, 2009 7:51 pm
Wedging is not done to reduce oil drag, but to improve the balance factor.
1275 motors in particular have bugger-all counterweighting. Wedging makes the crankpin side of the webs lighter, has similar effect to increasing counterweight size. Less main bearing wear.
Blading is done to reduce oil drag. Unfortunately, it undoes much of the benefits of wedging, most of the metal removed comes off the counterweights. :!:
PostPosted: Thu Jun 25, 2009 10:36 am
brief update.... took it to my machine shop and they reckon that can't be bored out, so I spoke to GR and he suggested I bring it up to Sydney and he can sleeve the block and do the rest of it for me
need to organise a work trip to Sydney
PostPosted: Thu Jun 25, 2009 9:23 pm
Yep, I'd go along with a small piece of the diff cogs throwing into the gearbox and jamming it, it has happened to me in a Minor when I broke 5 teeth off a cluster.
"Chip off the old block", as it were.
PostPosted: Thu Jun 25, 2009 10:03 pm
read it again.... the diff cage picked up a tooth and smashed it into the diff housing which jammed the shaft behind the diff
PostPosted: Sat Jul 04, 2009 1:48 pm
minor update.... diff etc. is on it's way from UK, my spare block has been bored, and my cam is at GR's getting a refresh....
