It is currently Sat Jul 19, 2025 5:08 pm
 Post subject: New breather pipe setup
PostPosted: Sun Jun 28, 2009 11:01 pm
I got excited by some of the clips in the EAA videos put up by rookiepilot, so i decided to go into the garage and modify the breather pipe that i had.
The original was basically a PVC hose run from the rocker cover to the catch bottle. Very untidy.
I got some of these water pipe holders from the hardware shop, i don't know if the same are available in Australia. They are dirt cheap at 1.30euro for 10, and designed to hold hot water pipes, so i figured that it would suit my purpose.
I decided to fit them on top of the head studs at the front of the head. To do this i needed to drill out the hole to fit. I also had to cut a nut in half as there were no thin enough nuts in my stockpile.
The nut fits into the slot like this. It is not dead centre, but that does not really matter in the application.
Here is the first one fitted to the head stud. I only tightened it finger tight since you cannot get a spanner or socket in there. I used some Loctite 262 to lock the nut in place with all the vibration it is going to experience. If the head needs to come off, the plastic pipe holder can be sacrificed because they are so cheap, think of them as a consumable.
The second holder is now fitted and the aluminium 13mm tube is locked in place. You could use 12mm copper, or larger size pipe with larger holders.
Some hose is connected up, using 12mm copper 90 degree elbows to get it around the end of the rocker cover.
There are some clearance issues with the thermostat housing.
Solved by using the trick from the EAA site of using a piece of hose as a standoff and securing with a cable tie. I used some leftover 1/4" fuel hose, so it is reinforced.
Next step was to route the radiator overflow hose parallel to the crankcase breather pipe. Again using the hose piece standoff technique.
I also used the hose piece standoff technique at the rear of the engine bay to secure the fuel line, heater hose and choke cable so that there is no chance of any of them rubbing through on anything.
A good 2 hours spent in the garage. Thanks for the ideas rookiepilot :D
michael
PostPosted: Sun Jun 28, 2009 11:44 pm
you can buy a similar clip here. they use them now days with the plastic plumbing pipe work on new houses.
Mick why did you not bend the alloy tube and do it all in one piece :shock:
www.minisprintgt.com
PostPosted: Mon Jun 29, 2009 1:03 am
I left a lot of gear back home in Australia, so i don't have a proper tube bender, and geting one over here seems ridiculously expensive for the limited number of times i would use it, ie 4 bends. I can't even make one up out of scrap - don't have any. I had everything else except the pipe holders in my stockpile of bits, so it is a near zero cost exercise.
Bent tube would be the vent pipe mk 3 .... will get on to that later, probably after i come back.
michael
PostPosted: Mon Jun 29, 2009 5:14 pm
If you get a Mini rocker cover instead of a Morris 1100 cover it will have the outlet in the other end of the hump on the cover. :wink:
PostPosted: Mon Jun 29, 2009 8:45 pm
show us your catch can :shock:
PostPosted: Mon Jun 29, 2009 8:46 pm
This space for rent
I'll bet you say that to all the girls... :roll: :lol:
PostPosted: Mon Jun 29, 2009 8:47 pm
Not in those words :wink:
PostPosted: Mon Jun 29, 2009 11:35 pm
it looks cool, i dont want to sound like a d!ck but itsnt that a touch over extravagent?
Potato
PostPosted: Tue Jun 30, 2009 8:25 pm
G'day Mick,
Just a thought, you could of used the same size pipe but in chrome, you should be able to get it from a hardware shop, its used for plumbing purposes, i think it's called chrome kinko. just cut roughly to length, fill with sand and slowly bend to required shape, i have plumbed an inboard boat motor with it and it looks good .
Colin.
PostPosted: Thu Jul 02, 2009 6:22 am
i use what is available to me :lol: and if i did use a mini one, then i would not be able to make fancy pants piping would I???
Users browsing this forum: Bing [Bot] and 4 guests
