It is currently Mon Jul 14, 2025 6:19 am
Post new topic Reply to topic  [ 135 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7, 8, 9  Next
PostPosted: Wed Jul 01, 2009 8:28 am
Keep your 8A block Wombat, is worth holding on to.
Matt, I helped John K build Henrys 850 Targa car engine, & along with Henry, John Fitz & Andrew French we built the car, I have been part of the service crew for it while at Targa and was there when the engine was "rebuilt", along with its gearbox. I know whats inside that engine better than most and i know what it is capable of. I still use the guy that did the head for it, the cam grinder, the machine shop, the guy that made the roller rockers and the ballancer. What exactly do you know that i dont???
Have a Nice Day.
PostPosted: Wed Jul 29, 2009 3:04 pm
Keeping this thread alive..
Are 850 pistons the same as 998?
They're the same bore.. but i'm imagining there's something magically different.
If not, I assume they could be MADE to fit.
PostPosted: Wed Jul 29, 2009 4:02 pm
No, there smaller and they have a higher deck height. When you fit 998 pistons to an 850 block you need to bore it out a fair bit to make the std size 998 pistons fit & you need to machine a bit of the top of the block too. You need to use the 998/1100 rods too. :D i havent done one for a few years now so hopfully someone will back me up.
Have a Nice Day.
PostPosted: Wed Jul 29, 2009 4:06 pm
I was just going on the miniresource.com specs list
850cc
bore/stroke: 62.93x68.26mm
bore/stroke: 62.93x76.2 mm
PostPosted: Wed Jul 29, 2009 4:16 pm
no thats wrong. :roll:
Std 850 bore size is 2.477
Std 998/1100 bore size is 2.543.
Have a Nice Day.
PostPosted: Wed Jul 29, 2009 4:22 pm
AHHHHHHHH
That would explain why the calculated capacity for the 998 came out at 948...
Right...
my 869 just lost half a cc..
PostPosted: Wed Jul 29, 2009 4:38 pm
cush wrote:
i'd be happy if it still had an 850 engine number... :P
Get a 1098, deck the head & block to increase the C.R.
Then stamp it with your 850 engine number :idea:
PostPosted: Wed Jul 29, 2009 4:41 pm
Yeah, I've got a 1098.
I might just do that..
Or just take my own advice..
http://www.ausmini.com/forums/viewtopic.php?t=37267
cush wrote:
Get a 1275.
PostPosted: Wed Jul 29, 2009 4:47 pm
I see you can still get overbored 850 pistons on minispares uk
but 200 ex shipping w/o rings (i think).... yeow...
Who does 'em in ausland?
PostPosted: Sat Aug 01, 2009 12:45 pm
Supercharged
can we just overbore to 998 size pistons? and how many thou is that over std?
PostPosted: Fri Aug 14, 2009 3:39 pm
I was just thinking this.
PostPosted: Fri Aug 14, 2009 4:20 pm
Overbore about .060" and you can fit stock 998 64.6mm pistons.
You will need to deck the block by about .156" though, as they are shorter pin to crown height.
PostPosted: Fri Aug 14, 2009 4:33 pm
I have a set of STD 998 pistons -NOS I could be encouraged to part with :wink:
David L
PostPosted: Fri Aug 14, 2009 5:15 pm
I would use a set of std size 998 Flat top Hepolites. Very strong pistons & flat topped to help with raising the compression. With a small chamber head you will have a nice little 850 hottee.
Have a Nice Day.
PostPosted: Sat Aug 15, 2009 8:23 pm
'ow mooch?
Users browsing this forum: No registered users and 24 guests
