It is currently Wed Jul 23, 2025 9:56 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 53, 54, 55, 56, 57, 58, 59 ... 568  Next
PostPosted: Sun Jul 05, 2009 8:54 pm
Worked on the '65 Deluxe doors. Filled in the old mirror mount holes. Filled a couple of minor holes and epoxy primered both doors. I hate doors. Also discovered two of my door hinges have been bodgied with a 5/16 bolt and now need new RH door hinges.
(watched the Daytona Nascar in HD!) On holidays again now so progress city here we come.
Regards
Dave K.
PostPosted: Sun Jul 05, 2009 9:09 pm
I worked on my front subframe for it's engine conversion. Good progress today and really enjoyed myself. :D :D
Phil
PostPosted: Sun Jul 05, 2009 9:11 pm
Had to move the shell from the soon-to-be-demolished shed to one of those Supercheap temporary 6x3 carports. The shell has a subframe in the back and back wheels. Nothing else. I tied a rope between the front tower mounts, stood in the engine bay, put the rope over my shoulders then walked in a shuffle the 30m I had to move the car.
So my mini moved, 0.00001 Hp and max speed 30m in 5 minutes (= 0.36 km/h).
M
PostPosted: Sun Jul 05, 2009 10:18 pm
today I finished up some V block type things so I can wedge cranks on my mill with moderate repeatability..
blokeinamoke wrote:
PostPosted: Sun Jul 05, 2009 10:40 pm
You will need an adjustable stop block to put under the crankpin, the crank will move during the cut otherwise. :shock:
Yes I know this...:mrgreen:
I made one out of a 1/2" bolt and a pair of locknuts.
PostPosted: Sun Jul 05, 2009 11:46 pm
yeah mate thats my next job, I will make a spacer that bolts onto the bigend and then to my table then I just have too move it around so I can get all the web things... the crank will need to be moved 4 times to wedge the whole thing.
blokeinamoke wrote:
PostPosted: Mon Jul 06, 2009 7:44 am
It should look like this when finished milling.
Don't take the cut back onto the counterweight beyond the main bearing journal or you will lose counterweighting.
See on the front web here, the cut runs out just above the edge of the main.
After milling, remove all the sharp edges and radius it around the crankpins with a linisher (fixed belt sander).
An angle grinder and flap wheel is too hard to control on this job. You might slip and mark the journals... :shock:
PostPosted: Mon Jul 06, 2009 8:54 am
ginger ninja
ginger ninja
Yesterday Cherry got new shocks and knuckle joints :) I'm kinda useless so I didn't do it myself :oops: but she's much happier now and the difference is amazing!
sports850 wrote:
PostPosted: Mon Jul 06, 2009 8:57 am
I tried my hand at trimming also, not too bad, well maybe it just looked good after the glue fumes :D
Im here to learn!
PostPosted: Mon Jul 06, 2009 9:16 am
I did this:
Tried to add shocks to my hydro mini using thie really helpful how to:
http://www.ausmini.com/forums/viewtopic.php?t=12180
Gee those cobalt drill bits make all difference when drilling through the arms.
2008 Prado GXL
PostPosted: Mon Jul 06, 2009 9:26 am
This space for rent
Fat Boy Dave wrote:
Tried to add shocks
Tried to? Does that mean you didn't succeed?
PostPosted: Mon Jul 06, 2009 9:29 am
Today I have done nothing!! Yesterday I drove it around melbourne with other mini addicts and annoyed the public (ok just aided thier hearing problems) :!: :D
PostPosted: Mon Jul 06, 2009 10:26 am
Yesterday got the 1275 engine off my mini thanks to kennomini
now the hard part......
PostPosted: Mon Jul 06, 2009 12:22 pm
Did all the gorund work, drilling holes, adding dry suspension shock mounts, now just need to add the chock absorbers. :wink:
2008 Prado GXL
PostPosted: Mon Jul 06, 2009 1:16 pm
Hydro on mine was a little low, only 2 fingers at front- so I pumped it up to 3 fingers. 8)
