It is currently Sat Jul 19, 2025 4:38 pm
Post new topic Reply to topic  [ 44 posts ]  Go to page 1, 2, 3  Next
 Post subject: Stock engine on boost.
PostPosted: Tue Jul 07, 2009 5:44 pm
So i have a 1976 998 and am going to be putting a turbo on it. Just wondering if anyone has an idea on what sort of poundage the stock internals car handle.
I was hoping to run around 16+ pound but am sort of worried..
The engine is under rebuild at the moment so now would be the time to change it all..
Cheers.
PostPosted: Tue Jul 07, 2009 6:00 pm
High heel ninja
Talk to Graham Russell.
Doogie
PostPosted: Tue Jul 07, 2009 6:22 pm
wind up the boost until you hear a loud bang and thats probably your limit :P
Mister White Keys
"He who has the most toys, Wins"
1963 Austin Countryman Woody
1964 Morris 850 Van
1967 Austin Countryman
1975 Range Rover 2 Door
2004 Subaru Forester XT
2015 Potts Teardrop Camper
RIP 1990 Citroen BX 16Valve
PostPosted: Tue Jul 07, 2009 6:24 pm
the thing is, its in pieces now, and really don't see that being a good idea :lol:
p.s. i know its a joke.
PostPosted: Tue Jul 07, 2009 6:29 pm
If it is already in pieces you don't need to wind the boost up.
PostPosted: Tue Jul 07, 2009 7:07 pm
NAV-MAN
Not going to get any boost until the engine runs. Speak to GR, he's the guru.
PostPosted: Tue Jul 07, 2009 7:42 pm
how do you mean stock?
head gasket will withstand 12psi with arp studs and good gasket but i think you will have issues with 16psi
basically depends on tune and pistons but crank and rods will easy hold 16psi
hope that helps
PostPosted: Tue Jul 07, 2009 8:08 pm
hope that helps
it does. I will contact the guy that has been suggested above.
Just want to find out what sort of pressure the internals can withstand so i can have an idea on my limits. Cheers.
PostPosted: Tue Jul 07, 2009 9:42 pm
I wouldn`t go past 10psi if i were you & i`d be dropping the compression ratio to about 8:1 or 8.5:1 max if you`re contemplating running on pump fuel
However,,, if you`d like to creep it up to the edge, then maybe 15psi but it will probably be pushing the limits on pump fuel
did i mention anything about pump fuel?
Oh & if you`re using pump fuel then i`d make sure the max ign timing is kept at or under 20deg
are you using it with pump fuel???
PostPosted: Tue Jul 07, 2009 9:54 pm
AVGAS comes from a pump :P
I'm really not contributing much to this thread i'll admit :D
Mister White Keys
1964 Morris 850 Van
PostPosted: Tue Jul 07, 2009 9:56 pm
no no no,,, you have it all wrong,,, AvGas comes from the bottom of an AV :-)
PostPosted: Tue Jul 07, 2009 10:02 pm
I dunno about the other states but in NSW if caught using avgas on the street, they hang you by your gonads and relieve you of $5K. :shock:
PostPosted: Tue Jul 07, 2009 10:04 pm
well,,, NSW regs suck then ey??? I don`t mind being hung by the gonads but $5K ???? Bugga that !!!!!!
PostPosted: Tue Jul 07, 2009 11:34 pm
Supercharged
how much $ are you prepared to spend?
and what are you going to be using this motor for?
PostPosted: Tue Jul 07, 2009 11:47 pm
if caught
That's the only bit you have to worry about Kev
Users browsing this forum: watsupskip and 77 guests
