It is currently Sat Jul 05, 2025 4:35 am
 Post subject: IDENTIFICATION 1 1/2 SU
PostPosted: Mon Jul 06, 2009 5:37 pm
I have found a brand new 1 1/2 SU in my shed, can somebody help me identify it and what vehicle does it fit.
The tag on the fuel bowel the alloy tag reads AUD660 , on the body is the following cast markings AM/PDC1.
The body of the fuel bowl AUD2140
THANKS
Alpine Mountains full of Mini's and Moke's.
PostPosted: Mon Jul 06, 2009 6:10 pm
I just found a reference to an AUD660 on a Hilman Hunter.
I will keep digging. :wink:
PostPosted: Mon Jul 06, 2009 6:40 pm
Hillman Hunter 1975
1496cc - 1724cc - HS4C
Interconnect = LHIC
Needle = CUD1044
Needle Guide = AUD4288
Needle Screw = AUD4251
Piston Spring = AUC1167
Damper = CUD4103
Jet = AUD9814
Needle and Seat = WZX1100
Float = WZX1300
Throttle spindle = WZX1316
Throttle Disc = WZX1387
Piston spring AUC1167 = Yellow, Load at length 8oz - 2.750in.
Needle AUD1044 = ABW
That is all I can find.
 Post subject: SU
PostPosted: Mon Jul 06, 2009 8:34 pm
Well done morris 1100
PostPosted: Mon Jul 06, 2009 8:41 pm
Does the choke linkage look a bit funny? :?
 Post subject: SU
PostPosted: Mon Jul 06, 2009 8:46 pm
Yes a little different, I nearly put it on my 1275 moke today as my SU has seen better days
PostPosted: Mon Jul 06, 2009 8:48 pm
In the book the HS4C has a different choke that throttle linkange setup.
If it fits use it! :lol:
PostPosted: Mon Jul 06, 2009 9:19 pm
cool I i'v got two trie thies
Number on Float Bowl H?L3BW-F6 A_3302H Fuel bowl is on the Clutch Side
Bugger the other one doesn't have numbers but has the bowl on the Radiator side...but under the butterfly shaft "Opposite side" from the linkages it has 3 dots in a triangle and #2
PostPosted: Mon Jul 06, 2009 9:22 pm
you did a what??
PostPosted: Mon Jul 06, 2009 9:24 pm
ow crap...didn't look at what I typed again
Should have read..."Cool I'v got two of these"
PostPosted: Tue Jul 07, 2009 7:12 am
Morris! How come you know so bloody much?
PostPosted: Tue Jul 07, 2009 6:06 pm
Because I am farking good. :mrgreen:
Here is how I did it....
Step 1) I Googled "AUD660 SU" and the first result on the page was this site... http://www.oldengine.org/members/diesel/SUCarburettors/SUCarbMenu.htm
Step 2) Read that page, scratch my head and start opening pages and came up with this one.... http://www.oldengine.org/members/diesel/SUCarburettors/SUButecParts4.htm
Step 3) Find AUD660 on that page and it listed Hilman Hunter but no details.
Step 4) Go to my trusty SU book..
Step 4a) Look up Hillman, dang no Hillman. :cry: Look up Chrysler, Bingo.
Step 5) Copy everything from teh book into the above post.
Step 6) Bask in glory. :lol: :lol: :lol:
PostPosted: Tue Jul 07, 2009 8:00 pm
Hay Morris what about Mine :shock:
