It is currently Sat Jun 21, 2025 10:55 am
PostPosted: Wed Jul 08, 2009 8:15 pm
OK I,ll try again, that cover has to come off first in order for me to have access to the main nut, around the back is two very tiny screw holes that nothing really fits into to do the job of removal, as I said I have a jewellers screwdriver but its too short, I want to fit my Motolita for the MiniShow and am rapidly running out of time, I have been looking at this problem for three months and have made no headway, I realize EXACTLY what do after the cover is removed its very simple but the cover has to be removed first and I am not using brute or mechanical force due to the condition of the steering wheel
[img][img]http://img194.imageshack.us/img194/4087/snailsteeringwheel.jpg[/img][/img]
PostPosted: Wed Jul 08, 2009 8:19 pm
I have never done this before, so I'm only asking questions and making suggestions.
How deep are the holes?
Can you borrow or buy a suitable screwdriver?
How certain are you that the cover is held on by screws? Most steering wheels I have encountered, the cover just peels off, but I have never done it on one of these wheels.
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
PostPosted: Wed Jul 08, 2009 8:23 pm
I can assure you that cover is held on by tiny,tiny screws at the back and the tool has to be something very different from any other screwdriver, like I said I have a jewellers screwdriver and its to short
PostPosted: Wed Jul 08, 2009 8:33 pm
How long is your jewlers screwdriver? I have some here that are from a very cheap Chinese set that have a shaft about 3inch's long. They had to be screwed in there, so you can surely buy a screwdriver to suit. Have you looked around?
Ryan Filippi
Minis In The Gong
[email protected]
PostPosted: Wed Jul 08, 2009 8:35 pm
http://www.epinions.com/prices/Jewelers ... _Set_Tools
Ryan Filippi
Minis In The Gong
[email protected]
PostPosted: Wed Jul 08, 2009 8:36 pm
There is a couple of studs in the back of the cover and they poke into holes in the wheel.
The Leyland book says...
Remove the steering wheel pad by gently levering each end with a broad bladed screwdriver.
PostPosted: Wed Jul 08, 2009 8:39 pm
That's how I got mine out of the `70 Matic, 15 years ago.:mrgreen:
PostPosted: Wed Jul 08, 2009 8:46 pm
Well if the advice is to lever gently I,ll have a go after I finish my Tangelo its out again to the shed ! :?
PostPosted: Wed Jul 08, 2009 9:18 pm
Mystery solved yes there are no screws just two metal pins ! :evil:
And I now need a 1 1/2 inch socket and I,m away, I thought my 1 1/4 was big enough :?
Not much time and still jobs to do to get the "Snail" ready for the MiniShow.
PostPosted: Wed Jul 08, 2009 9:20 pm
Really? What a surprise.
You probably should thank the bloke that told you the correct way to remove the cover. Nah, why bother.
PostPosted: Wed Jul 08, 2009 9:21 pm
dude the socket is either in the green bin (on the tray) or it's on one of the Sparcos, the BIG ball joint socket is next to it.
you are after the 1 5/16, remember that they are the black steel one.
PostPosted: Wed Jul 08, 2009 10:28 pm
Thank you Mr Morris much appreciated, mind you I was suprised by how much force it took to gently lever it off.
Looking forward to the argy-bargy to get the wheel off now !
PostPosted: Wed Jul 08, 2009 10:38 pm
I've got the correct socket if you need to borrow one.
Brett.
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Wed Jul 08, 2009 10:53 pm
Thanks Brett, I,m sorted now :) just have to look for it.
PostPosted: Wed Jul 08, 2009 10:54 pm
Seems my suggestion was not too far off the mark after all :roll:
Users browsing this forum: Bing [Bot] and 93 guests
