It is currently Tue Jul 15, 2025 8:53 am
Post new topic Reply to topic  [ 46 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Thu Jul 09, 2009 10:53 am
that will work,,, just all that extra brake pipe going to the back, only to come back up to the handbrake is a bit pointless,,, to add horsepower, you need to add less weight :-)
PostPosted: Thu Jul 09, 2009 11:03 am
Yeah I was thinking about neatness.
Maybe i'll just bring the pipework straight into the car right near the handbrake and then back out.
PostPosted: Sat Jul 11, 2009 9:56 am
Is the top outlet the front brakes? or is the bottom outlet?
This is my next hurdle. Hopefully someone knows... I don't have any workshop manuals here :cry:
PostPosted: Sat Jul 11, 2009 3:44 pm
Top outlet goes to the rear.
Here's a pic of the setup on my car without the Pressure Limiting Valve.
Curly
PostPosted: Sat Jul 11, 2009 6:33 pm
ha,,, i thought the top cyl is the front one ???
PostPosted: Sat Jul 11, 2009 6:38 pm
I think these pipes on Barney are original off a late Clubby, the top port goes to the rear.
PostPosted: Sat Jul 11, 2009 6:56 pm
Its funny, i just went to look at the cars i have here to confirm, 4 of the tandum braked minis,,, 2 have top pipe going to rear & 2 have top pipe going to front,,, BUT!!! the "more" factory looking pipes have it going to the rear.
2 other 2nd hand valves i have in stock here, "look" like factory pipes & the top pipe goes to the rear
PostPosted: Sat Jul 11, 2009 6:58 pm
LS1380 wrote:
Try this Will-hope it helps :) ohh sorry about the glitter!
funny hey??? this one looks like the top goes to the front as well
PostPosted: Sat Jul 11, 2009 7:08 pm
Are they a stepped bore? (can't remember)- if not, it shouldn't matter a rat's.. :lol:
PostPosted: Sat Jul 11, 2009 7:14 pm
yeah , bottom bore is bigger, top bore is small,,, that`s why i figured the top one was for the front,,, It`s weired how i don`t tend to bother to look much until i need to :-)
I wonder how many minis out there have got it wrong :-)
PostPosted: Sat Jul 11, 2009 7:18 pm
Very interesting. Will be interested to see what the miniking says.
Anyone got a pic of the last LS off the lines engine bay?
PostPosted: Sat Jul 11, 2009 7:22 pm
If that is the case, you will get more psi produced in the top port than the bottom- I think the top should therefore go to the fronts.
PostPosted: Sat Jul 11, 2009 7:23 pm
It does not have to be an LS, it could be any 78 Mini.
PostPosted: Sat Jul 11, 2009 7:41 pm
yep,,, my thoughts exactly
& yeah Morry,,, any/all of the Aussie tandum cars
I`ll have a gork in the books at dads place tomorow to mke sure
PostPosted: Sat Jul 11, 2009 7:47 pm
The Leyland Motor Corporation 'Comprehensive Workshop Manual' doesn't mention which outlet is front or rear - it also doesn't show or mention a stepped bore.
Curly
