It is currently Mon Jul 21, 2025 1:57 pm
PostPosted: Thu Jul 09, 2009 11:37 pm
if i were to get wider wheels (13x7) what sort of cutting would need to be done to the front wheel arches? where and by how much?
is there anywhere someone can point me to investigate a "how-to" for minis to get a better idea as to what would have to be done?
FOO
PostPosted: Thu Jul 09, 2009 11:43 pm
There are some pics of how I did mine here:
http://www.ausmini.com/forums/viewtopic.php?t=41844&postdays=0&postorder=asc&start=15
MRBN is quite low, and I could run 50 profile Yokos on the 13x7s fine on the street.
Once I hit the track, the braking and cornering forces made the front wheel arches rub on the tyres.
Due to the large offset, the tyres did not hit the inner guard, but you do need decent size flares.
Oh, and if you're thinking of buying Darren's rims, they look just as good up close as they do in the photos.
PostPosted: Thu Jul 09, 2009 11:46 pm
I have templates to mark out to cut the guards. What type of guard extension are you using. I make my own steel ones.
If you want to see how I do it I have a shell that I am doing now.
www.minisprintgt.com
PostPosted: Fri Jul 10, 2009 9:42 am
is that template in "emailable" form? I am geting wheels for my Rover and although its a little time before I tackle it, something like this would be an awesome help.
PostPosted: Fri Jul 10, 2009 10:25 am
i have bought the wheels already, and i am 1/2 way through extending the flares that were on there using fiberglass, i was just wondering what sort of cutting needed to be done
PostPosted: Fri Jul 10, 2009 4:26 pm
You can get them from the minispares.com you need to be a member and its in fitting instructions. I used them. They are ...ok. Not perfect by any means. Maybe as they are roundie.. late roundie I think and I am a clubman pilot.
D
Users browsing this forum: No registered users and 64 guests
