It is currently Sat Jul 19, 2025 12:15 pm
 Post subject: Help identify 18 engines
PostPosted: Sun Jul 12, 2009 1:00 pm
To cut a long story short I have 18 engines I want to identify.
I want to know the cc, year, make and model that each engine may have been used in, some of these may also be moke engines.
The confusing ones first;
(1)Engine # V7I786 P (either a P or a 10)
(2)Engine # 903/1J (or a U)H/U13Y9the last set is stamped upside down :? any idea why?
(3)Engine # 8Y/U/H21047
(4)Engine # 99H834AJ/H6765
(5)Engine # 99H834AJH011167
(6)Engine # 99H33AAJH(either a U or a 0)11655
(7)Engine # 99H905AJH000527
(8)Engine # 99H834AJ/H4869
(9)Engine # 99H119/H1082
(10)Engine # 99H860AJH003068
(11)Engine # 9YA/Ta/H7996
(12)Engine # 99H834AJH008690
(13)Engine # 10Y/Ta/H36977
(14)Engine # 10YF/U/H9041
(15)Engine # 10004672
(16)Engine # 100112389
(17)Engine # 1015/10875
(18)Engine # 10Y/Ta/H56233B
So obviously their are some strange combinations (some are strange to me) and it is a lot of info I'm after but if you can help out identify any engine I'd really appreciate it.
PostPosted: Sun Jul 12, 2009 1:04 pm
(1)Engine # V7I786 P (either a P or a 10) ---> probably Victorian Police stamped from being shaved at some point in it`s life
(2)Engine # 903/1J (or a U)H/U13Y9the last set is stamped upside down :? any idea why?---> probably an industrial engine or maybe a Moke donk
(3)Engine # 8Y/U/H21047---> 850cc
(4)Engine # 99H834AJ/H6765---> 998cc
(5)Engine # 99H834AJH011167---> 998cc
(6)Engine # 99H33AAJH(either a U or a 0)11655---> 998cc
(7)Engine # 99H905AJH000527---> 998cc
(8)Engine # 99H834AJ/H4869--->998cc
(9)Engine # 99H119/H1082--->998cc
(10)Engine # 99H860AJH003068---> 998cc
(11)Engine # 9YA/Ta/H7996---> 998cc
(12)Engine # 99H834AJH008690---> 998cc
(13)Engine # 10Y/Ta/H36977---> 1098cc
(14)Engine # 10YF/U/H9041--->1098cc
(15)Engine # 10004672--->1098cc
(16)Engine # 100112389--->1098cc
(17)Engine # 1015/10875--->1098cc
(18)Engine # 10Y/Ta/H56233B--->1098cc
PostPosted: Sun Jul 12, 2009 1:08 pm
This space for rent
This one is a Victorian Police-issue number -- you'll have to rely on other identifying features of the engine to figure out what this is.
This is an 1100 out of a 71-73 Leyland Clubman or Van IIRC.
year, make and model is a bit specific... you should be able to identify most of them via searching on here
Kennomini wrote:
(1)Engine # V7I786 P (either a P or a 10) Victorian police issue number, issued in 1986, could be anything
(3)Engine # 8Y/U/H21047 850
(4)Engine # 99H834AJ/H6765 late clubman 998
(5)Engine # 99H834AJH011167late clubman 998
(6)Engine # 99H33AAJH(either a U or a 0)11655late clubman 998
(7)Engine # 99H905AJH000527late clubman 998
(8)Engine # 99H834AJ/H4869late clubman 998
(9)Engine # 99H119/H1082late clubman 998
(10)Engine # 99H860AJH003068late clubman 998
(11)Engine # 9YA/Ta/H7996 mini deluxe 998
(12)Engine # 99H834AJH008690late clubman 998
(13)Engine # 10Y/Ta/H36977 mini K
(15)Engine # 10004672 clubman 1100
(16)Engine # 100112389 clubman 1100
(17)Engine # 1015/10875 clubman 1100
(18)Engine # 10Y/Ta/H56233B mini K
PostPosted: Sun Jul 12, 2009 3:52 pm
Thanks Simon that's the kind of info I'm after :D
PostPosted: Sun Jul 12, 2009 6:56 pm
I can do better but it will cost you. 8)
PostPosted: Sun Jul 12, 2009 7:35 pm
Aww come on you know you want to shed some light on this...
PostPosted: Sun Jul 12, 2009 8:09 pm
(1)Engine # V7I786 P (either a P or a 10) Victorian police issue number, issued in 1986, could be anything Yep
(2)Engine # 903/1J (or a U)H/U13Y9the last set is stamped upside down :? any idea why? No idea!
(3)Engine # 8Y/U/H21047 850 Yep, later car with Australian motor, so 64/65.
(4)Engine # 99H834AJ/H6765 late clubman 998 Leyland Mini / Mini S. ADR27A Air pump engine, late 76?
(5)Engine # 99H834AJH011167 late clubman 998 Leyland Mini / Mini S. ADR27A Air pump engine, late 76?
(6)Engine # 99H33AAJH(either a U or a 0)11655 late clubman 998 ADR27A Air pump engine, late 76? The A in the engine number should be a 4
(7)Engine # 99H905AJH000527 late clubman 998 I have nothing for the 905 code, maybe 78 Mini or late Moke?
(8)Engine # 99H834AJ/H4869 late clubman 998 ADR27A Air pump engine, late 76?
(9)Engine # 99H119/H1082 late clubman 998 MiniMatic. The code is too early to be a Clubman.
(10)Engine # 99H860AJH003068 late clubman 998 I have nothing for the 860 code.
(11)Engine # 9YA/Ta/H7996 mini deluxe 998 Yep
(12)Engine # 99H834AJH008690 late clubman 998 ADR27A Air pump engine, late 76?
(13)Engine # 10Y/Ta/H36977 mini K Morris 1100 from about 65, not Mini K
(14)Engine # 10YF/U/H9041 Moke about 1970
(15)Engine # 10004672 clubman 1100 Mini 1100 or Mini 1100 Van (poverty Clubman/Van) about 1972
(16)Engine # 100112389 clubman 1100 Clubman, late 72 early 73
(17)Engine # 1015/10875 clubman 1100 This universal code covers all Leyland Mini and Mini S and vans and Mokes up till Zetland closed and the first few months of Enfield, so 74 and 75.
(18)Engine # 10Y/Ta/H56233B mini K Morris 1100 from about earyy 67, not Mini K
PostPosted: Mon Jul 13, 2009 7:01 pm
Big thank you morris that will give me a good idea on what I've got.
(1)Engine # V7I786 P (either a P or a 10) Victorian police issue number, issued in 1986, could be anything Yep I noticed yesterday this has an 1100 stamp on the back of the block so 1098cc
(6)Engine # 99H33AAJH(either a U or a 0)11655 late clubman 998 ADR27A Air pump engine, late 76? The A in the engine number should be a 4I thought it could have been a 4 but it looks so much like an A :roll:
