It is currently Thu Jul 31, 2025 8:51 am
PostPosted: Wed Jul 15, 2009 6:29 pm
Where the front subframe meets the footwell is it reinforced on a moke!?
Does anyone have underside picture of where rear of front subframe mounts!?>
thanks
PostPosted: Wed Jul 15, 2009 6:32 pm
Milatsmadmini
by 2 sheets of metal being overlapped... sure... :lol:
PostPosted: Wed Jul 15, 2009 6:53 pm
I thought their was a box section down their somewhere but I'm not sure if it's the same area.
PostPosted: Wed Jul 15, 2009 9:09 pm
Yep, there's a box section there, sticks down about 2 - 2 1/2 cm at the front. Thats why there are holes in each footwell with one of the subframe mounting bolts down them.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Wed Jul 15, 2009 9:11 pm
My `79 Moke has 5 patch layers above that... :cry: :P
I will fix it, when I get time and a round tuit...
PostPosted: Wed Jul 15, 2009 9:17 pm
Yeah, the moke floors are an inch "higher" than the mini floor pans,,, so there is a step "up" from the rear mounting point of the front frame, & yeah it`s sort of a box section where it mounts
PostPosted: Wed Jul 15, 2009 9:22 pm
If you want to look at my 67 moke at the set up your welcome. One side is still original and the other I have repaired/replaced. Both had some rust between the metal overlap
www.minisprintgt.com
Users browsing this forum: ClubmanGT and 94 guests
