It is currently Sat Jul 26, 2025 1:48 am
PostPosted: Sat Jul 18, 2009 7:33 pm
He's only packing it away because he doesn't want to loose his bet
http://www.ausmini.com/forums/viewtopic.php?t=15365
And Gafmo, when have you ever seen a piano with two rows of keys & that many pedals?
I'm sure Cush often goes out to the shed to play with his organ :!:
PostPosted: Sat Jul 18, 2009 7:39 pm
I'm guessing its a orgin of some sort then and can't see anyone playing it unless its a Granny
PostPosted: Sat Jul 18, 2009 9:25 pm
poeee wrote:
Neglect at it's finest.
Can I have that under my username? :P
PostPosted: Sat Jul 18, 2009 9:32 pm
gafmo wrote:
GET ASTRO in the SHED :roll:
ok
:P
PostPosted: Sat Jul 18, 2009 9:36 pm
And for the true enthusiasts, I'm currenty uploading a loopable version of the youtube vid...
I call it "The Petrol Feature".
http://users.on.net/~cushways/petrol%20feature.wmv
PostPosted: Sat Jul 18, 2009 9:38 pm
A night light also 8) Now your thinking of him :wink:
PostPosted: Sat Jul 18, 2009 10:07 pm
It's a heater...
I don't want him getting cold.
PostPosted: Sat Jul 18, 2009 11:01 pm
cush wrote:
It's a heater...
Or the petrol.....
IS NOW BACK ONLINE AFTER SOMETIME..... SORRY TO ALL, FOR NOT REPLYING TO PM'S!!
PostPosted: Sat Jul 18, 2009 11:22 pm
Just grab a screwdriver and give the top of the float bowl a whack with the handle of the screwdriver and try it again. :wink:
While I have your attention, what's causing this? Crusty dried up seals around the float bowl lid that haven't seen fuel for ages?
I'm asuming your suggestion makes an even bigger fountain? :)
PostPosted: Sat Jul 18, 2009 11:41 pm
No, he's suggesting a cure. It's possible crusty old fuel has made the float valve stick, which should otherwise shut the fuel flow off before it gets that high in the bowl.
The gasket has probably been like that for ages. Normally it doesn't really do much.
Glad Astro is safe and dry.
PostPosted: Sat Jul 18, 2009 11:48 pm
The fuel does not normally reach the dried out gasket until you go around a corner.
It is like "awdmoke" said that the needle valve is stuck causing the float bowl to overflow. Even with a new gasket it would still overflow out the breather hole.
Giving the float bowl a whack with a soft but firm object can unstick the needle or clear the blockage. But it that does not cure the problem you just undo the 3 screws, lift the lid and give the needle a wiggle. It is a real easy fix. Actually there is a (small) chance that the next time you start the pump it may have fixed itself.
PostPosted: Sun Jul 19, 2009 9:58 am
Well that's good news...
I was hoping to give it a thrash up the driveway... :)
And it's annoying, because it means i could've DRIVEN it into the shed, rather than pushing it on it's 50 point turn entry.
