It is currently Fri Aug 15, 2025 9:48 pm
 Post subject: New Clubby Heater Tap
PostPosted: Wed Jul 22, 2009 12:46 pm
How much and from where?
thanks
PostPosted: Wed Jul 22, 2009 1:14 pm
http://www.ausmini.com/forums/viewtopic.php?t=44289
I pick up one of these dirt cheap as they were on 'clearance' for $11 - has been replaced with a plastic one for around $40 When I got mine there were only 4 left in Queensland and 15 in Australia in Repco store. I had to go to Beenleigh to get it. Beaudesert also had 2. Might pay to give a ring if thay haven't gone already ( was 3 months ago)
David L
PostPosted: Wed Jul 22, 2009 2:04 pm
I think heritage mg in sydney or whatever its called still have some.
about $130+ though each
PostPosted: Wed Jul 22, 2009 2:27 pm
thanks heaps
PostPosted: Wed Jul 22, 2009 8:15 pm
if your going for orginality go ahead, otherwise I would just rip the tap out and plumb it straight to the radiator in the unit which makes the water flow continualy. This does not have any affect on the heat inside the cabin unless you have the heater fan on. This cost $0
PostPosted: Wed Jul 22, 2009 8:25 pm
plumbing it straight thorough can be a pain in a clubby with a fresh air vent still in place. The car forces air through the heater regardless. it makes your feet pretty toasty in summer...
I picked up a later rover valve once, the inlet and outlet are designed for the next size heater hose up, but can be made to fit if you really want to.
http://www.minispares.com/Product.aspx? ... E%20TYPE...
http://www.minispares.com/Product.aspx? ... OINT%20O...
PostPosted: Wed Jul 22, 2009 8:40 pm
You can fit a generic heater tap anywhere along the hose.
Holden and Ford have both used cable operated heater taps in their cars and good spare parts places carry them.
Plumbing the heater straight will be a pain. According to the handbook the fan is only meant to be used at low speeds as there is sufficient airflow when moving at speed.
PostPosted: Wed Jul 22, 2009 8:48 pm
http://cgi.ebay.com.au/New-2port-Heater-Tap-Valve-Holden-Kingswood-HQ-HJ-HX-HZ_W0QQitemZ350226606276
PostPosted: Wed Jul 22, 2009 9:09 pm
plumbing in a tap is a pain and also connecting it to the shell of the heater. Toasty toes during Summer...nope...its in my wifes daily drive and she would complain if it was
PostPosted: Wed Jul 22, 2009 9:22 pm
My heater doesnt have a tap, and my toes used to get quite toasty on long drives with the fresh air vent. Since removing the pipe connecting the fresh air to the heater its a lot better, but its still noticeable without shoes on.
The other problem i have is, i was going to fit the piping for the front screen back into the car, but thought it might make my window fog up in certain conditions. This could probably be rectified by hooking up the cable for the flap in the heater, but i'm a bit lazy and its low down on the to do list.
PostPosted: Wed Jul 22, 2009 11:30 pm
Hey Morris that one would be direct replacement wouldnt it - No changing anything around, because the old kingswood used exactly the same tap as the clubman/leyland mini didnt they??
PostPosted: Thu Jul 23, 2009 8:14 am
anyone know this?
PostPosted: Thu Jul 23, 2009 5:17 pm
I don't know if it is exactly the same. I think the heater hose may be the next size larger. But you can make it fit and it is cheaper.
Should I go out to the shed and measure a Clubman one?
PostPosted: Thu Jul 23, 2009 5:32 pm
I believe that clubman heater connections use 1/2 inch heater hose, and the later rovers use 5/8th. It might be the same for later commodore heater hoses as well. It shouldn't be too difficult to stretch the hose over however if you use rubber grease and/or heat the hose.
PostPosted: Sun Aug 02, 2009 2:56 pm
Sorry to bring up this old thread but did anyone ever find out if there was a good replacement for the Clubman heater tap as mine is seized!
thanks
Users browsing this forum: No registered users and 421 guests
