It is currently Fri Jul 18, 2025 11:13 am
 Post subject: roll cage
PostPosted: Mon Jul 27, 2009 1:39 am
hey all, who does everyone use to build roll cages?
need s to be cams approved, and would prefer a full cage with door bars,
in sa
also what sort of money should one expect ?
cheers jamie
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Mon Jul 27, 2009 8:52 am
Join / attend a local historick club meet and ask around. Not all cages / builders have the CAMS approval. Sorry don't know of anyone down your way.
PostPosted: Mon Jul 27, 2009 2:26 pm
Jamie try rory thompson at sailsbury[ his company is ASP racing]
He can build or you can build to cams specs and he can inspect it.
They ain't cheap. Cold drawn tube is expensive and you have to get the bends right.
The roll cage in my sprint cost over $800 just for the tube. There are not too many places around here that sell it.
www.minisprintgt.com
PostPosted: Mon Jul 27, 2009 10:59 pm
Mad Dat Has made a few nice cages speak to steve and he will put you in the right direction
Walker Chassis also do heaps of cages for lots of cars
Option Three Bond cages are fine to just make sure you have all the paper work for CAMS
Make sure you seat is mounted in the correct position BEFORE the cage is made or you could be in big trouble
Read the CAMS manual and have a good under standing of what is required
UMMM last cage i know of being built was a half cage and that cost $1200
Do you need a full cage i only have half .. I know quite a few who have rolled with half cages and now worries
Half cage with side intrusion bars if i was going to do one again ..
Let me know if you get stuck
Cheers Beanie
I am the son of the STIG
HOTBRICKS
http://hotbricks.org.au/
'65 NCF MINI.....
