It is currently Wed Aug 06, 2025 6:47 am
PostPosted: Wed Jul 29, 2009 4:42 pm
Hi all,
I have just fitted the rear trailing arms to my moke and fitted the wheels. Passenger side is ok but on drivers side the tyre hits the rear sub frame bolt. I have already fitted a new rear shaft. The inside of the tyre is about 15 to 20 mil closer than the other side. Where the trailing arm attaches to the sub frame i have taken out the shim/spacer this makes no difference.
Is there anything else that i can check THANKS Dean :?
PostPosted: Wed Jul 29, 2009 4:53 pm
Sounds like a bent subframe. If you get an adjustable camber/castor kit that might fix the problem, unless you have two different length trailing arms! :lol:
PostPosted: Wed Jul 29, 2009 4:58 pm
If you have had the trailing arms rebushed, you may have hed them reamed out of alignment as well. if the old arms weren't a problem, and the new ones are,have the bushes checked for concentricity.
PostPosted: Wed Jul 29, 2009 6:36 pm
Mick wrote:
concentricity.
:mrgreen:
David L
PostPosted: Wed Jul 29, 2009 7:10 pm
Its the word of the day you know ;)
That and the number 4 with the letter M according to Sesame Street
con·cen·tric (kn-sntrk) also con·cen·tri·cal (-tr-kl)
adj. Having a common center.
[Middle English concentrik, from Medieval Latin concentricus : Latin com-, com- + Latin centrum, center; see center.]
con·centri·cal·ly adv.
concen·trici·ty (knsn-trs-t) n.
PostPosted: Wed Jul 29, 2009 7:23 pm
Thanks for the replys will go and check a few measurements.
Good word of the day!!!!!
PostPosted: Wed Jul 29, 2009 8:12 pm
the arm itself might be bent, but not visually apparent.
PostPosted: Wed Jul 29, 2009 9:35 pm
More than likely the arm is bent
PostPosted: Thu Jul 30, 2009 5:33 am
If its not a bent arm then it could be a worn hole on the inner mount.
PostPosted: Thu Jul 30, 2009 6:55 am
Thought only minis use the bush? - mokes have two needle bearings.
I take it that the wheels/tyres are the same and the offset are also the same on both sides?
Regards
Dave K.
PostPosted: Thu Jul 30, 2009 7:31 am
You're absolutely right....they won't even accept the bronze bush if you wanted to....it won't be that then...
PostPosted: Thu Jul 30, 2009 8:09 am
Whatever happened to 'dog' being the word of the day? or other simple words like that
PostPosted: Thu Jul 30, 2009 8:53 am
Wheels are same size and rim offset is the same.
Trailing arm does have roller bearings at each end
Inner hole on subframe is not worn or slotted
Looks like i will have to dig out another rear trailing arm, clean and paint GRRRR
Thanks everyone
PostPosted: Thu Jul 30, 2009 9:27 am
When I first got the car and fitted new rear bearings and shockers I found the rear wheel on the passenger side rubbed the shocker. I used a spacer (both sides) made from a cut down brake drum to give me some clearance. I've since gone the whole hog and installed adjustable suspension all round and although not adjusted yet I am hoping I can adjust the clearance to suit without the spacer.
David L
Users browsing this forum: Bing [Bot] and 45 guests
