It is currently Thu Aug 07, 2025 2:09 pm
 Post subject: grease guns
PostPosted: Wed Jul 29, 2009 9:13 pm
Do I need to get a specific one to work my nipples
PostPosted: Wed Jul 29, 2009 9:24 pm
Bow chika wow wow!
no just the standard one that comes with the off the shelf guns. i'd get a flexible attachment tho, they come in handy for when you need to work on awkward angles...
1962 850,Frog
PostPosted: Wed Jul 29, 2009 9:35 pm
Cheap guns work ok, but the grease nipples are rubbish. More grease will squirt out around the nipple than get pumped through it. Especially with the ball joints on a mini which is the main reason you need one.
Shell out for a reasonable grease gun imho and save yourself the pain. saying that, 50 dollars gets you a perectly reasonable Toledo grease gun.
PostPosted: Thu Jul 30, 2009 12:04 am
On this subject, is there a trick to getting a grease gun to unlatch from a nipple easily?
I always seem to have the hardest time doing this and it's not made any easier when your fingers are greasy and you can't twist the bits you need to twist. Am I doing it wrong?
PostPosted: Thu Jul 30, 2009 12:07 am
wog muscles
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Thu Jul 30, 2009 12:32 am
A couple of things I do. Have a BIG tin of brand new 1/4"unf nipples and a 6 sided socket to remove them. If they look cruddy throw them away and relpace with new ones.
Another thing is to scrounge all the wrecking yards and get the little rubber caps of the brake bleed nipples and use them to cover the grease nipples. Stops them from rusting .
After you have pumped the grease in and the connector won't come off, this is caused by the residual hydraulic pressure in the hose . Just release the pressure by opening the bleed screw on the gun pump.
www.minisprintgt.com
PostPosted: Thu Jul 30, 2009 8:58 am
That must be it! Thanks for that. I'll give it a shot.
PostPosted: Thu Jul 30, 2009 9:21 am
Good idea about the caps David :wink: I have an extension piece about 18" long - gets down the back of the motor to the nipple on the top of the diff housing for the gear linkages.
I have found the more you push the hose coupling onto a nipple the more it leaks - but if you push on then pull back a little it seals fine.
David L
PostPosted: Thu Jul 30, 2009 9:22 am
yeah, the upper balljoint is a PITA.
If it won't take grease, the joint is good (little wear), therefore it needs lube to stay good.
If it does take grease, it is probably worn, therefore rooted, and not worth greasing :evil:
PostPosted: Thu Jul 30, 2009 9:58 am
What grease guns are people using? What is a 'good' one?
I know Toledo..that's about it.
PostPosted: Thu Jul 30, 2009 10:20 am
Wouldn't know - I've had it for 44 years :shock:
David L
PostPosted: Thu Jul 30, 2009 10:29 am
Bought a toledo and the casting cracked after about 30 minutes use. :cry: As a result it leaked hydro fluid all over me and the garage floor.
2008 Prado GXL
PostPosted: Thu Jul 30, 2009 11:20 am
This space for rent
I've got a little Toledo one and it's rubbish - the handle is made of thin bent tin and it's too flimsy, it bends whenever there's any backpressure.
Find one with a good sturdy steel handle...
PostPosted: Thu Jul 30, 2009 11:33 am
These guys look fairly good.
~$110 - 10 Year Warranty.
http://www.macnaught.com.au/sub_level.php?ref=flexigun&bc=Greasing_Equipment
PostPosted: Thu Jul 30, 2009 12:39 pm
I never knew this and always had this prob, thanks for the tip :)
Used to have 2000 Cooper Classic Sport 500, No 338, currently miniless :(
