It is currently Wed Jul 30, 2025 1:54 pm
 Post subject: Traveller seats
PostPosted: Thu Jul 30, 2009 1:53 pm
What should I be expecting to pay for some traveller rear seats?
PostPosted: Thu Jul 30, 2009 2:21 pm
One million dollars!!!
That's if you can find some. Best bet would be to try the UK.
the Clubman Estate seats should fit the same. Otherwise just copy the parts locally. They are not very complex. Any sheet metal place could press the parts up, then you can get an upholsterer to finish them off.
I had the bits, and got a local motor trimmer to recreate the seats with a close match to the front seats.
PostPosted: Thu Jul 30, 2009 2:55 pm
http://www.newtoncomm.co.uk/cars/mini/p ... =24&type=1
It's a start
PostPosted: Thu Jul 30, 2009 2:56 pm
There we go..
http://www.newtoncomm.co.uk/cars/mini/p ... =20&type=1
mike wasn't far off..
PostPosted: Thu Jul 30, 2009 3:23 pm
The seats don't have steel frames, they are wooden underneath. The best bet would be to copy an existing set of frames and get the newton commercial foam and covers.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Thu Jul 30, 2009 3:48 pm
They have a pressed steel support / hinge channel under the front edge.
The wood is nothing special, so yeah Bunnings will do for that.
From memory I think I paid about $400 to have them trimmed locally, but that was 3 years ago.
PostPosted: Thu Jul 30, 2009 3:59 pm
Just saw a pretty good set go for 31 pounds on ebay UK, add shipping to that and its still pretty reasonable i reckon.
PostPosted: Thu Jul 30, 2009 6:42 pm
Well bidding starts at $50!!!
Traveller rear
PostPosted: Fri Jul 31, 2009 1:32 pm
The seats in my early Traveller are just plywood bases with a piece of wood and bit of steel angle across the front. It hinges from two pins mounted on the companion boxes at the side. You could get it all from Bunnings.
1955 BSA C11G
1969 Triumph TR6R
PostPosted: Fri Jul 31, 2009 2:45 pm
Be aware that a set of Traveller rear seats won't just bolt in to convert a van to a Traveller. The floor and load bay of the Traveller is very different to a van, and there are supports up the sides for the rear seat backrest to fasten to.
If you want to convert a van to have a rear seat you are better to use a small Suzuki seat or similar that self-supports the backrest.
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
Users browsing this forum: Barkfast and 100 guests
