It is currently Sat Jul 19, 2025 2:41 am
 Post subject: Cam question very noob!
PostPosted: Sun Aug 02, 2009 3:17 am
Hey all looking at the cam listed in the for sale section
Question is is there different cams between 1275 and 1098 ?
Probably a silly question but one that had to be asked !
Cheers Jamie :)
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Sun Aug 02, 2009 5:24 am
A 1275 cam can be fitted to a 1098 no worries
Standard the small bore cams only have 3/8' wide lobes where as a 1275 has 1/2' wide lobes which are better.
Any decent cam grinder will stamp the end of the cam to tell what the cam has been ground to.
4efte powered Clubman
supercharged 998 race car
PostPosted: Sun Aug 02, 2009 7:40 pm
make sure the oil pump drive is the same..
Potato
PostPosted: Sun Aug 09, 2009 4:39 pm
Note that Cooper S pin drive oil pumps are now NLA, and so are the spider (star) adaptors for Morris 1100S/Mini 1275LS to fit their splined shaft pump.
I have steel laser cut adaptors in stock which will convert either type cam to take the 1275A+ slot drive pump. These pumps are the most commonly available now.
See my thread (with pics) in the mods forum-
http://www.ausmini.com/forums/viewtopic.php?t=39787
PostPosted: Sun Aug 09, 2009 4:46 pm
Hey kev,,, i think i will have to order a few of these adaptors from you (like maybe 10) ,,, i`m running out of spider cams & need to set up small bore cams into the Bimmer engines , by cutting all the lobes off them & fit those adaptors should do the trick & i can use the late slot drive pumps then
i`ll bell you next week sometime if that`s ok?
PostPosted: Sun Aug 09, 2009 4:53 pm
PM sent. :wink:
PostPosted: Sun Aug 09, 2009 4:55 pm
PM recieved & Reply sent
10-4 big buddy :-)
Users browsing this forum: No registered users and 23 guests
