It is currently Thu Jun 19, 2025 11:34 pm
Post new topic Reply to topic  [ 193 posts ]  Go to page Previous  1 ... 7, 8, 9, 10, 11, 12, 13  Next
PostPosted: Sat Aug 01, 2009 10:29 pm
Forum Graffiti
How about "Teh engine god"? :lol:
I think just 'God' would sum it up 8) :P
PostPosted: Sun Aug 02, 2009 12:55 pm
Graham the A-Series Guru?
Slide
1965 Mini Van (1360)
1970 Mk2 Cooper S (1310)
1978 Rover SD1 V8 (4.6)
 Post subject: Elder head
PostPosted: Sat Aug 15, 2009 10:45 am
Will this head be using Rimflo valves?
If not, what sort ?
 Post subject: Re: Elder head
PostPosted: Sat Aug 15, 2009 10:59 am
If not, what sort ?
I believe it takes any sort of mini valves, so if the buyer wants rimflo's, then they can have them... obviously if you're shelling out for the head & setup, the little bit extra for the valves wouldn't hurt much
PostPosted: Sat Aug 15, 2009 11:04 am
In the days when I was regularly working on Mini's I made the following references in discussions
John - Mini King
Glenn - Mini (mechanic at Mini King)
GR - God
ala - friend, "who were you on the phone to Daniel.."
me, "I was on the phone to God to find out what compression ratio I should be using with this cam, but earlier I was talking to Mini King about bits for my gearbox after Mini helped me get it apart..."
Daniel
PostPosted: Tue Aug 18, 2009 4:18 am
Hi GR
A benchmark has been set :D
1480cc KAD twincam
guru_1071 wrote:
looks like k.a.d have laid the gauntlet down.............
http://www.youtube.com/watch?v=erEYoyvF3V4
8)
Only makes 121 ft-lb and needs 9300 rpm to get to the 194hp.
C'mon GR, show em how its really done :wink:
michael
PostPosted: Tue Aug 18, 2009 8:43 am
Awww yeah!
PostPosted: Tue Aug 18, 2009 11:05 am
ha,,, there are faster engines out there , 220hp is what i`ve heard over the last few years.
But,,, that particular engine (the KAD one that Mick posted) is still being held up,,, you only have to listen to it,,, it`s still not screeming "clean" yet,,, & the last 1/4 of the throttle isn`t really doing much, tells me that there`s still heaps more to come from that engine,,, maybe more cam & Port design work could be sorted,,, & could certainly do with a pile more comp ratio
PostPosted: Tue Aug 18, 2009 5:51 pm
Maybe they need a faster dyno?
PostPosted: Tue Aug 18, 2009 8:24 pm
Oh dear, worry, worry...
Hi Michael
No Worries,But with a motor that size i would hope to see
135/140ftlb of torque with the elder head, my group NC motor
is making 123ftlb of torque and thats a 5port 1360cc but im
30 hp short of that KAD motor well done to the boys at KAD
Yes Matt there are motors in england making 220hp but not
KAD or 16 valve motor bike heads (NA) give the boys at KAD
some credit there no fools, and they do their home work, they
are a very smart bunch of guys and i dont think there would
be any one in england that would make more hp out of the
KAD motor than them, been there and met them they were
going to make and market my manifolds in england back in
1993.
Graham Russell
PostPosted: Tue Aug 18, 2009 10:55 pm
oh yeah,,,sorry if i sounded like i wasn`t impressed, please forgive me & i really mean that,,, i was only going on the sight, sound & feel of the donk on the dyno,,, & seems to me the thing isn`t quite free spinning (for whatever reason(s)
that`s all
& please don`t anyone try to start telling me about 9300 isn`t spinning,,, i know what 9300 feels & sounds like
i do tend to go more on the "Feel" of an engine quite a lot & i really didn`t mean to make out like i could do better,,, definately not,,, so for anyone reading this--> please understand that point,,, i havn`t made anywhere near that sort of grunt in my life (yet) :-)
my point was more towards the fact that i just feel that there is more to come from that N/A KAD donk
PostPosted: Wed Aug 19, 2009 4:09 am
Yeah Graham, that is what I meant by "only 121 ft-lb"
Using your estimates of peak torque:
121 ft-lb at 6500 is "only" 150hp
130 ft-lb at 6500 is 161hp
140 ft-lb at 6500 is 173hp
take 130 ft-lb up to 9000 and you get a whopping 222hp
and 140 ft-lb at 9000 is 240hp if you could maintain that torque at that end of the rev range (not saying you can't, but everything is compromised somewhere!)
All hypothetical of course, but it shows that it is possible to hold on to your money Graham :lol: .
I think you have one advantage over the KAD guys in that you are doing both the head and camshaft - they had to get Piper to make the camshafts for them, so maybe not as optimised as it could be?
I also notice that KAD are using 12.5:1 compression on Shell Optimax for that engine.
What compression and fuel would you need to run to get your 130/140 ft-lb ?
michael
PostPosted: Wed Aug 19, 2009 7:18 am
8)
interesting...
PostPosted: Wed Aug 19, 2009 7:59 am
Hi Michael
You need to make 108ftlb of torque to make 194hp @9300rpm
I only use 11.5/11.8 compression ratio in all my race engines
if you have a very efficient cylinder head you dont need big
compression(static)because the more you jam in the cylinder
the higher the compression you have when the mixture is
compressed, thats why F3 cars with there restrictorin the inlet
run 18to1 comp because theres nothing in the cylinder to
compress so the less there is in the cylinder the more you have
to compress it to get it to go bang.
like your standard mini when crusing on light throttel with
your vacume advance hooked up your running sum where near
70deg advance and you could run 16to1 with no problems
because theres nothing in the cylinder to burn, but it wouldnt
be happy if you put your foot down
Graham Russell
PostPosted: Wed Aug 19, 2009 1:58 pm
This is the inlet manifold for the 7 Port Ken Elder head. It will go under the bonnet of a clubman (just) roundnoses need a bump on the bonnet :P
These are the new valves, the angle on the back of the valve has been changed for better flow.
This photo is showing the centre exhaust and the route it has to take to get out on the original 8-Port Head
It's not as bad as it looks as it flows quite well.
This is the 7 Port for comparison:
