It is currently Mon Aug 04, 2025 12:53 pm
 Post subject: holy bootfloor
PostPosted: Tue Aug 04, 2009 5:32 pm
Hi guys,
just wondering how i would go about repairing this section, preferably without replacing with a new/donor panel?
thanks,
Steve =)
PostPosted: Tue Aug 04, 2009 11:28 pm
what is it?
PostPosted: Tue Aug 04, 2009 11:50 pm
The underside just behind the rear passenger seat section?
1965 Morris Mini Deluxe - 998cc SC12
PostPosted: Wed Aug 05, 2009 12:09 am
fiberglass perhaps
PostPosted: Wed Aug 05, 2009 3:30 am
The TIG
Hammer out a panel from some sheet metal and section it in. Easy. Once you spray some under coat on it nobody will ever know.
email - [email protected]
www.victoria-chiropractors.ca
PostPosted: Wed Aug 05, 2009 8:22 am
yep just bend up a new piece of metal thats the same size cut the old one out and weld the new one in easy.
cheers dan
Cheers Dan
PostPosted: Wed Aug 05, 2009 9:02 am
There is no rust that I can see. Just dolly the dings out from underneath
PostPosted: Wed Aug 05, 2009 9:35 am
yeah, it's the section where the bootfloor and rear seat ect join up. There are rust holes visible from the inside of the car as well.
so can i just cut out the section ( boot floor and seam of rear seat0, and weld in two new pieces of metal? I just don't want to do anything to impair the structural strength of the shell.
thanks
PostPosted: Wed Aug 05, 2009 9:42 am
How big are the rust holes? Maybe just fill them with a mig?
it looks pretty good to me...why hack it up?
you could fill the holes with a welder if small anyway. Treat with rust converter and you're away..
PostPosted: Wed Aug 05, 2009 10:51 am
sorry the first photo didn't really show the rust well..
so here's some more :)
gotta love the rotisserie!
this is the worst of it
followed by this.
I recon i can fill the rest of the holes with the mig, but I'm not sure about these...
PostPosted: Wed Aug 05, 2009 11:00 am
Rover Cooper
Holey SH1T....3 sand and 2 of cement.....new bum coming up here.....Good Luck..... :roll: :roll: :roll: :roll:
PostPosted: Wed Aug 05, 2009 11:12 am
nah man, that cement is gonna be used as body filler... :lol: :? :roll:
PostPosted: Wed Aug 05, 2009 11:42 am
Carfully remove the top skin in those small areas and make a replacement piece and weld in.
Dremel should work wonders in this instance! 8)
PostPosted: Wed Aug 05, 2009 12:57 pm
Polyfiller !!!
no seriously just it out and weld in some newness
