It is currently Fri Jun 27, 2025 8:46 pm
Post new topic Reply to topic  [ 117 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8  Next
PostPosted: Sat Aug 08, 2009 1:45 pm
miko wrote:
here's a little something from the eastern most state of australia.....
http://www.oldschool.co.nz/phpbb/viewto ... 17&t=17181
food for thought...!?
ah yes, that`s all nice & i`m sure he is going to love it & everything is quite dandy etc,,, just waaaaay tooooo heavy :-)
sorry but we`re (Tricky & i) will not be building anything near as Titantic as that,,, this will be pure lighweight & Blisteringly quick,,, that toyota & our mini will be chalk & cheese
PostPosted: Sat Aug 08, 2009 3:51 pm
some kiwi bloke wrote:
bla bla bla... Parry Reverse box
That looks like the answer to all the problems.
Never seen anything like it. Wonder where you procure one of those?
PostPosted: Sat Aug 08, 2009 4:01 pm
So would that reverse box work where it could transfer drive one way, then with some movement inside the box would produce drive in the reverse direction?
How would that go with the a chain drive though?
Simplify and add lightness
PostPosted: Sat Aug 08, 2009 11:35 pm
Not an option on chain drive.
He has done what I was suggesting way back on page one, but for the ingenious inclusion of a shortened toyota gearbox.
Really is quite simple and cheap to do.
Now, where is that gtir tail shaft and rear end......
PostPosted: Sun Aug 09, 2009 7:18 pm
pubudug wrote:
I've been chatting with the engineer some more and it seems like the mechanical reverse gear rule can be bent somewhat. We should be able to get away with an electric starter motor. He said all requirements state is that the driver has to be able to engage reverse in normal position while engine is running.
This can be achieved with a starter motor
He told me to check out how the aussie race cars do the reserve in their machines.. assuming they have reverse gear?
Tricky/Matt, you guys would know about this I suppose? I am not into motor sport at all :oops:
The Aussie racers just have teeth cut into the outside of the LR brake rotor. And a starter meshes with it.
PostPosted: Sun Aug 09, 2009 8:17 pm
This space for rent
That's ... ahem ... agricultural :shock:
PostPosted: Sun Aug 09, 2009 8:41 pm
It is not there to be used. It is only there to meet a CAMS rule that defines a car as having a reverse gear.
If it does not have reverse it is not a car and therefore can't race. :lol:
PostPosted: Sun Aug 09, 2009 10:42 pm
I have been looking into this for a while (non mini project) and have got as far as getting the motor, but reverse still worries me.
http://www.edge.au.com/forum1/viewtopic ... dge#p43693
this is about the best electeric option I have seen, but there are companies inthe states (Jeffco) that make a reverse hub, which also seems nice, my motor was adapted to a VW box uing that as a diff and reverse.....
I can only please one person per day,
Today is not your day,
Tomorrow is not looking good either.
PostPosted: Mon Aug 10, 2009 12:09 am
http://www.edge.au.com/forum1/viewtopic.php?f=9&t=4767&p=43693&hilit=REverse+electric+edge#p43693
I am a bit confused as to how this operates. The starter motor gear drives the motorcycle output sprocket??
So obviously we should need all the rest of it such as driven gear, diff, drive flanges etc etc
The engineer I am sure would be happy with this. for $2k is this pretty good.. even if you have to make up the rest of the drive train...
I am not sure about the spiel about output sprocket shaft business since all the kits in UK leave this shaft unsupported. I guess it can't hurt
I will email this link to the engineer and see what they say
Also, its very interesting about this Aussie race cars.. lol
[/quote]
PostPosted: Mon Aug 10, 2009 8:32 am
Gee,
I wish I had said that........
Its the same setup that Matt and I have come up with. Except ours was inline with the drive sprocket not sitting above it.
That though, is a very professional answer to the 'reverse' problem and well engineered. Kudos to them!
PostPosted: Mon Aug 10, 2009 1:41 pm
These electric options look the business but I can't imagine them withstanding some robust application, say a motorkana event?
I wonder how the hayabusa powered clubmans have sorted the reverse? The ones registered in Australia I mean.
PostPosted: Tue Aug 11, 2009 12:55 pm
for road use I think the starter motor would be fine.. I dont care if I have to reverse at 5km/h!
Tricky, with your inline option, are you going with a one way engaging gear of some sort or a cluth or something? how would the gear ratio's work out?
PostPosted: Tue Aug 11, 2009 7:29 pm
I was going to use a planetary gear system to keep ity all inline with the drive sprocket.
This should give us excellent reduction along with the final drive ratio.
Mechanical diesnegagement via on-way bearing or magnetic clutch.
PostPosted: Tue Aug 11, 2009 7:44 pm
any idea how much torque a magnetic clutch from a A/C pump can hold?
PostPosted: Tue Aug 11, 2009 7:45 pm
IT may be worth looking at what people building the bugges are using, anything that will hold up to a hayabusa engine and 33 inch tall dirt tyres with snatching loads, will be more than fine with any mini style application.
From this site
http://www.minibuggy.net/forum/drivelin ... ons-2.html
A List;
Spool: Homebuilt, no differential, chain driven, cheapest way to go.
Transworks: Has reverse, inboard brake option, direct drive. $2295
Sand Bullet: Has reverse, inboard brake option, direct drive. $3995
Quaife CD Axle: Chain driven, reverse. $3195
Quaife POWERtec: Has reverse, direct drive (not shown on website). $4795
JEFFco Reverse Diff: Has reverse, chain drive. $3500
JEFFco Reverse Hub: Has reverse, chain drive, no diff. $2500
Roberto Gearbox: Econo unit for under 50HP. $1250
Roberto Gearbox: Direct drive for CVT. Live axle. $2000 - depending on options
Jaxsports Reverse Gearbox: Has reverse, chain drive. Available straight or 90 degrees. $2800
Go to the link for further links.
Somewhere on the site there is a chap using a Honda FWD gearbox cut down with good results, but damend if I can find the page.
