It is currently Sun Jul 27, 2025 4:18 pm
PostPosted: Mon Aug 10, 2009 7:06 pm
hey guys,
i've just had a bigger motor put in my mini and the battery seems to JUST turn the motor over. it's gone from a 998 to a 1330 with LOTS of work done.
suggestions on what sort of battery i need would be greatly appreciated.
The BLUE BRIK ;-)
PostPosted: Mon Aug 10, 2009 7:13 pm
is the earth strap from the gearbox to the car earthed properly? i had the same problem but it wasnt the battery is was the earth strap, i had paint on the body and wasnt earthing properly
PostPosted: Mon Aug 10, 2009 8:01 pm
you shouldnt need a bigger battery, but if you are getting a new one get one with a large cold crank value, mines somewhere around 500 or so
1962 850,Frog
PostPosted: Mon Aug 10, 2009 8:08 pm
maybe thier considerable differnace in compression between the two engines and the starter motor is having troubles turning the motor over so a biggr battery is required
PostPosted: Mon Aug 10, 2009 8:11 pm
There is no point in asking if you need a stronger battery if you won't tell us the specs of the battery that you currently have.
PostPosted: Mon Aug 10, 2009 8:14 pm
why not? I bet his current battery doesn't eat it's weeties, and is just a general wussbag....
see, I'm sure he hasn't got a 550 CCA calcium battery - I've got about an 8m sloping driveway and I've driven my car up it using the starter motor a few times :D
PostPosted: Mon Aug 10, 2009 8:25 pm
Mate, get a high cca gel jobby; that will even get Granny to go :roll:
PostPosted: Mon Aug 10, 2009 8:29 pm
Is nobody going to ask about the condition of the starter motor?
I went through the routine of the starter motor letting the engine down only a few months ago. a properly sorted and rebuilt starter motor spins my 1310 over like a sewing machine. A 1330 shouldn't be any different.
Pull it down and check the condition of the brushes, also the condition of the commutator (should be fairly flat and no pitting.
Look for discoloration of the conductors relative to one another on the rotor as this will indicate a problem with the windings.
Also check your battrery leads for damage as well as your terminals.
PostPosted: Mon Aug 10, 2009 8:31 pm
They can't afford to ask about starters after buying big CCA gel batteries.
My own theory is not to buy anything until you know what the problem is.
PostPosted: Mon Aug 10, 2009 8:33 pm
nah, we just keep grabbing another starter motor off the shelf as each one dies.... see, we could also ask if the motor is too far advanced, but that'd be too easy as well
PostPosted: Mon Aug 10, 2009 10:08 pm
I'm in a similar situation but i dont have the original battery. What do people recommend for a cheap reliable battery?
PostPosted: Mon Aug 10, 2009 10:15 pm
Tomboss Breweros
My van has a DIN77 700 cca sealed battery. No problemo, runs the stereo well :wink:
My clubby has a 480cca battery, no problem.
Get your battery tested, it's probably a bit weak.
Has it ever been dead flat? Lead acid battery killer, knocks off 10% each time.
kimini wrote:
Jimmyinamini wrote:
 Post subject: buggered batt
PostPosted: Tue Aug 11, 2009 3:26 am
had same prob on my evil mini,turned out to be rooted solenoid,so i would get another solenoid and check,also check condition of yer earth strap...
First you get the money,then you get the power,then you get the Mini.
 Post subject: Re: buggered batt
PostPosted: Tue Aug 11, 2009 10:05 am
may be the earth, the engine bay has just been freshly painted.
most likely is the weakness of th battery it is VERY small.
and YES the battery has been dead flat several times since the motor has has been rebuilt which was only a week ago.
The BLUE BRIK ;-)
PostPosted: Tue Aug 11, 2009 10:41 am
holla for a MARSHALL!! (im in the glovebox), hasnt failed me yet.
Users browsing this forum: winabbey and 109 guests
