It is currently Tue Jul 22, 2025 8:51 am
PostPosted: Mon Aug 10, 2009 7:46 pm
Seem to be having a few issues!
Think it all stems from the rather shocking find that my cones had NO retaining bolts! So any way, inserted the cone compressor and managed to get the knuckle clear of the the suspension arm, but the knuckle is siezed SOLID!
I had a hammer and grips and rust off and CRC on it but didn't budge! So then tried to get the trumpet off the cone, and still SOLID!!
:cry:
So anyone got any tricks to help?!
PostPosted: Mon Aug 10, 2009 8:31 pm
don't be shocked... there never were any
that's normal
that's normal too
beat the sh!t out of it until the trumpet smashes then fit hi-los, or remove the top suspension arm
PostPosted: Mon Aug 10, 2009 8:34 pm
Get an electric jig/hacksaw and cut the bastard trumpet up.
Take top arm out.
Remove cone.
Fit new cone + hilos + knuckle.
Replace top arm.
Viola!
PostPosted: Mon Aug 10, 2009 8:43 pm
yeah I would go with beat the crap out of it as well.
Just remember, if it can't be fixed with a hammer it must be electrical :)
I think i read that on here on a sig!
PostPosted: Mon Aug 10, 2009 8:47 pm
Even that rule can be bent.
SU fuel pumps respond well to a clout when they refuse to move.
PostPosted: Mon Aug 10, 2009 9:44 pm
But its the mechanical bit that stops it :lol:
PostPosted: Mon Aug 10, 2009 10:05 pm
Thought the cones had a collared bolt holding them in position!?
PostPosted: Mon Aug 10, 2009 10:21 pm
ok,,, i hate that people call the rubber part the "Cone",,, it`s really the spring or the donut
the cone is really the cone shaped ally trumpet/strut thing
so,,, take the top arm out ,,,, if you have to -->smash the old alloy "CONE" shaped trumpet/strut thing & fit all the new bits
there,.,,, i said it ,,, i feel soooo much better now :-)
PostPosted: Mon Aug 10, 2009 10:50 pm
From a Mini shop listing Miniman.......
Mini front suspension upgrade kit
Never compromise with your safety, insist on the best quality components
Mini front suspension Kit, this kit is of the highest quality and is great value for money. The new rubber cones will give you that softer ride, the Hi-lo’s will allow you to lower or raise the car at the turn of a nut and the ball and cups will stop any squeaks.
PostPosted: Mon Aug 10, 2009 10:55 pm
oh yeah,,, i know that everyone "calls" them cones & always have done,,, i just hate the term cone for the spring when the ally strut is the cone "Shaped" item,,, so maybe it`s just the miss-planation of the terms that gives me the sh!ts :-)
PostPosted: Mon Aug 10, 2009 10:58 pm
Matt still doing your hi lo kits?!!?
PostPosted: Mon Aug 10, 2009 11:06 pm
the rubber donut is called a cone, because of the shape of the inside bit that the rubber is bonded to - the old parts book calls it a cone and a strut (trumpet)
http://www.somerfordmini.co.uk/eshop/in ... page&id=52
52.
FAM3968 CONE, spring, rubber, standard 2 Requires metric threaded cone compressor to fit.
FAM3968P CONE, spring, rubber, standard 2 Very high quality non-genuine item; requires metric threaded cone compressor to fit.
C-STR687 CONE, spring, rubber, uprated 2 For fast road or competition use.
53 .
2A4355 STRUT, steel (also known as 'trumpet') 2 1959-61.
21A530 STRUT, aluminium (also known as 'trumpet') 2 1961 on; may be used on earlier models.
:oops:
Users browsing this forum: No registered users and 65 guests
