It is currently Sun Jul 27, 2025 8:56 am
PostPosted: Wed Aug 12, 2009 8:40 pm
Hi guys, one of my engines seems to blow a fair bit of black smoke. I adjusted the fuel mixture, but it still doesent seem to make much difference?? Is there any other reason aside from too much fuel (Rich) why an engine would blow black smoke??
Thanks Lockie.
PostPosted: Wed Aug 12, 2009 8:47 pm
Worn jet, needle or both.
Rebuild the carbie.
PostPosted: Thu Aug 13, 2009 3:33 pm
Had this problem on my old clubby,it could be the anti pollution canister sucking fuel from the fuel tank straight into the rocker cover.I blanked all the lines on the canister and this fixed the problem. I had to retune the engine due excess fuel before.
Regards Felix
1967 Morris mini Deluxe
1968 Buick Riviera
1979 HZ Kingswood
1979 CM Valiant
1982 Jaguar XJ6 series 3
2002 VX HSV
2013 Mazda 6
2018 Gt Mustang
PostPosted: Thu Aug 13, 2009 4:55 pm
Regards Felix
sounds plausable but I don't have this on my mini, so can't be that. Must be the carby then??
PostPosted: Thu Aug 13, 2009 5:52 pm
ginger ninja
ginger ninja
Lockie91 wrote:
Regards Felix
If it is the 1978 mini, it should by law have the anti pollution gear (someone correct me if I'm wrong).
I vote carbie problems
sports850 wrote:
PostPosted: Thu Aug 13, 2009 6:03 pm
jess wrote:
Lockie91 wrote:
Regards Felix
nah its actually bluey's spare engine. not the 78 mini. The 78 mini runs like a charm, not a single bit of smoke. :)
PostPosted: Thu Aug 13, 2009 6:22 pm
Your not having too much luck with your engines. Give us a yell if you still want that 1100 that came with the black mini.
Simplify and add lightness
PostPosted: Thu Aug 13, 2009 6:37 pm
Make sure the engine isnt secretly on fire :lol: :lol: :lol:
PostPosted: Thu Aug 13, 2009 6:58 pm
The Forkmeister
Maaaaate, just had this priblem with Scarlet, and it turned out to be an air leak :? , one of the hoses off the manifold that I normally had blocked off was open. I blocked it up again and no more black smoke. 8)
May the fork be with you.
PostPosted: Thu Aug 13, 2009 7:10 pm
hmmm, thats certainly something im going to look for now :) thanks mate :D
