minimanic wrote:
I've fitted spark plug thread inserts before, comes in a kit with a tap and inserts, you tap out the thhread and screw in the insert with some lock tite on it. The one I did for a 'tempory' fix lasted several years and quite a few plug changes
You can get the kits from most auto places and it was quite cheap when I bought mine.
I have the `Recoil' kit here, I can do it for you cheap if you bring me the head.
Before you go that far pull the plug out and shine a torch in the hole, see if threads are
really missing.
It's damned hard to strip the plug threads in an A series cast iron head... but too easy in modern alloy ones.
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
